Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Carpet cleaner not releasing water from the tank to wet the carpet
SOURCE: Bissell 1950F Wet Pick Up Vacuum Cleaner
Dear Schonaldo, Thank you indeed for your reply. I phoned Bissel to locate a service centre close by as I did not have the expertise to do any repairs. The Bissel call centre referred me to their in-house service people who confirmed your finding that the machine is gravity fed, however they also suggested that sometimes there is a problem because of an air lock. Their suggested solution was to fill the tank and depress the trigger a few times and, if this did not work, to hold the trigger down for a period. It took me a day or so to get back to the machine and it could have been that the air lock was dispelled by time, however, when I re-filled the tank and depressed the trigger everything started working again. I wonder also whether I may have put too much cleaner solution into the tank, which may could have further exacerbated an airlock situation. Alternatively, I notice that the air vent at the top of the tank is very small and I have inserted a needle to open it up a little, thereby creating more pressure. Anyway hoorah - everything is working OK.
Posted on Sep 01, 2007
  • 57 Answers
SOURCE: Bissell ProHeat 2x Upright Carpet cleaner-water tank valve
www.usavacuum.com/category-s/387.htm
You can find the parts you need here
Posted on Feb 21, 2010
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
BissellCSR
  • 276 Answers
SOURCE: MY CARPET CLEANER WILL NOT RELEASE THE WATER AND
Click HERE for a copy of the User's Guide.
Posted on Jun 24, 2010
heatman101
  • 43501 Answers
SOURCE: The bissell proheat turbo carpet cleaner is not sucking up water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jer
Posted on Sep 30, 2010
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
My Bissell Proheat 8920 carpet cleaner does not suction water
its pluged check the hose that goes to the tank ill bet it hasnt ben rinsed the dirt sets in the hose and dries and it gets like concreet but this will solve the proublam
May 21, 2012 | Vacuums
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell carpet cleaner
heatman101
teydh
Nov 30, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
113 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
