Question about GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator
I have a GE side-by-side, model GSS25VGMD WW. The problem we are experiencing is with the ice maker. When water goes to the ice maker the water doesn't stop, it continues to pour into the ice tray resulting in one big frozen block. How can we fix this?
  • 29 Answers
SOURCE: ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Posted on Jan 28, 2008
  • 262 Answers
SOURCE: ice maker problem
try turning down your water inlet pressure go about half way and play with it from there also check the tube going to the icemaker to put water in the maker make sure it is all the way into the ice maker
Posted on Feb 03, 2008
arikrom
  • 528 Answers
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Posted on Jan 02, 2010
  • 552 Answers
SOURCE: Ice storm knocked out power
This video explains how to repair a kenmore ice maker
You can also post your question in the Kenmore Repair Forum
Kenmore Repair Articles
Posted on Feb 26, 2011
  • 586 Answers
SOURCE: My Liebherr ign 2566 freezer
Hello there,
You need to check the water inlet valve, it is having a problem, it is not shutting close after filling the ice maker with water. It is already defective hereby causing water to pour out into the tray therefore producing the big slab of frozen water.
You will have to test and replace the water inlet valve. That way, it will stop pouring water into the already made ice that is in the tray.
Hope this helped. All the best Elect_Comp
Posted on Sep 23, 2011
I have a GE model TPX 24BPBA WW and have a water leak on my floor. I disconnected the icemaker water feed and leak stopped. What's wrong
do you live in an area where there are rodents such as mice ? if yes there is a possibility that they have eaten the plastic water line that feeds from the ice maker water valve to the ice maker itself . when they get thirsty you would be surprised what they will actually chew through to get water. regardless the cause, you probably have a broken water line between the ice maker water valve and ice maker unit .
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
Ice Maker
Put less water into the ice tray.
Sep 23, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ice maker problem
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
GE GSS25VGMWW / GSS25VGMCC Side by Side Refrigerator Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
