Question about Frigidaire GLEQ2152ES Electric Dryer
Squeaks when drying - Frigidaire GLEQ2152ES Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
Drum squeaks on rotation. can drum be lubed?
would not lube the drum but the two small wheels that the drum rotates on sometimes their "axles" get dry and rusty and will squeak. Put some antisieze on them and see if the noise goes away.
Mar 16, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
Maytag dryer model number LDE840ACE squeaks during the drying cycle
That is probably a Wheel. More likely the wheel over the heater. I recently worked on one of these and posted a pictorial:
My Maytag dryer repairs
Jun 20, 2012 | Maytag Dryers
My dryer is squeaking like crazy. What is wrong
all dry have roller that the dry drum roll on an all so there a little wheel that the dry belt go around you may need to replave them are if you know have to take the dry apart an clean the lint out of the botton of your dry an if you left any item in your pocket you will find them in the botton of your dry make sure you unplug your dry b4 you work on it ok
Apr 24, 2010 | Frigidaire FEX831CS Top Load Stacked...
While drying for short time the dryer starts to squeak
Probably a dry bearing
.You would have to gain access into the dryer to establish which bearing/s it is.
You would then need to see if lubricating the bearing/s, would cure the squeak..
If it does not, then you may have to fit a new bearing/s.\
Hope this helps.
Dec 22, 2009 | Maytag Dryers
Squeaks & takes longer to dry
The squeaks are normally a sign of dry drum roller bearings. You either need to lube the shaft and bearing of the roller or replace the roller completely.
The drying problem sounds like you have a least one bad thermostat, need to check and replace the faulty thermostat
Sep 22, 2009 | Kenmore Dryers
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
Dryer squeaks while drying sounds like drum rubbing on something
A squeak can also be a slipping belt or something caught between the drum bearings usually the front but could be the back one.
Jun 14, 2009 | Dryers
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
91 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
