Question about Aiwa NSX-AJ20 CD Shelf System
Aiwa cx-na555 headphone jack size? Where can I get an adapter for this size and standard size found on most computers?
2 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: headphone jack size
Headphone jacks are either 1/4" or 1/8". If it's about the size of a pencil, its 1/4". If it's more like the size of your mouse wire, it's 1/8".
Posted on Apr 16, 2009
Aiwa cx-na555
Either the tray loading mechanism is out of alignment, or the flex-cable for the tray is bad.
Dec 17, 2013 | Audio Players & Recorders
What is the headphone jack size of the fender sp-10 10 watt amp
Call your local stereo store. These items are very standardized.
There are 2 standard sizes for headphones. the one for PCs and phones is the smaller size. An amp or receiver probably take the next size up. If you screw up and get the wrong size someone like Radio Shack or the like will have an adapter that sells for a buck or 2.
Jul 03, 2012 | Fender Sp-10 Electric Guitar Amp 10 Watt
Headset size for samsung sw531 mobile phone
Hi brentcopeman,
U would say yes this is the case. Nearly all mobile phones have a 2.5mm headphone jack up to the newest smartphones and walkmans that have been in production on the last year or 2 some of which use the standard headphone jack size.
I might add that if you have headphones that you like already to buy one of these:
http://www.amazon.com/Headset-Adapter-3-5mm-2-5mm-Converter/dp/B000LMBJMA
That way you can use the headphones you already have and insert them into the phone using the adapter and don't have the added cost of new headphones unnecessarily.
Hope this helps you out.
Dec 14, 2011 | Audio Players & Recorders
Can microphone be used with computer?
Yes, if it's similar to what is pictured above and your computer has a microphone input on it. As long as the computer has the input the most you would need to do is get an adapter for the microphone to get the plug to the correct size. Often times microphones have a 1/4" jack which looks like a larger version of what your standard ipod headphones has. The plug would need 1/8" to work on a standard computer. 1/8" is the size of the standard headphones. Adapters can be purchase from RadioShack for couple dollars.
Hope this was helpful
Ray
Mar 02, 2011 | Samson Dynamic Vocal Microphone
How to hook up a Sony Large Screen FD Trinitron WEGA stereo color TV (KV-36FS13) to a aiwa cx-na888
first of all i did fing the sony manual on sony's website http://www.docs.sony.com/release/KV36FS13.PDF
page 32 shows the audio out jacks , run the red and white wires to the inputs on the aiwa (i did not find a manual for the aiwa) if there are no input jacks on the aiwa then you can not connect it.
hope this helps
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have AIWA NSX-880 purchased in '99. During transportation it had got damaged. The CD part got damaged, the circuit got cracked. Recently gave it for repair, but I was told the CD tray cannot be repared....
This says Sony has taken it over, so Sony are unlikely to be interested.
AIWA Global Home
you might have more luck here
Aiwa Service Center in Hyderabad 040 24077328 Aiwa Repair Center in...
Or find someone like this
Aiwa CX NA555 Volume Repair
Basically you have an old and obsolete unit where no spares are available. This type of unit is deemed as a consumable unit, they break, you replace.
Nov 07, 2017 | Aiwa Audio Players & Recorders
Have Aiwa CX-NA555 with 3-CD turntable. CD's won't play because belt that connects motor to screw-drive on turntable is broken. Where can I get part number and/or replacement belt? Tx.
i have an aiwa cx-na555, the turn table want work the belt is good however when the table slides in it does not raise the turntablr motor into position because the yrllow does not unlock the turntable, its as though it is out of time, ineed help
Dec 07, 2009 | Aiwa Audio Players & Recorders
Headphone jack size
Apr 16, 2009 | Aiwa NSX-AJ20 CD Shelf System
Head phones adapter plug
There are three sizes of standard headphone plugs:
TRS audio jack: 1/4"
mini: 3.5mm (~1/8")
submini: 2.5mm (~3/32")
According to specs, your RCA system should accept the 3.5mm jack.
Although the manufacturer can pick any option, most large headphones would have the 1/4" and/or 3.5mm jacks. Small earbuds are more often 2.5mm.
RadioShack, or similar store, would have adapters to convert between these sizes.
Apr 21, 2008 | RCA RS2130i Shelf System
CX-NAJ20
hopefully u didnt get the male 1/8"-male 1/8" adapter (aka.. headphone-headphone sized jack)
..what u need is the headphone sized jack (that plugs into your ipod) with an end that is RCA stereo (red n white) these go in the back of the stereo...
hook everything up, and voila...
(no need to tell u what u already know, as far as pressin aux.. and all that..)
Oct 01, 2007 | Aiwa NSX-AJ20 CD Shelf System
Aiwa NSX-AJ20 CD Shelf System Logo
73 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
