I HAVE DAIKIN VRV III R 410A, FROM 1 0F THE 5 INDOOR UNITS( THE ONLY ONE THAT IS IN THE UPPER FLOOR OF A MAISONET HOUSE) COLD AIR 24 T EVERY 5-8 MIN YOU CAN HEAR A SOUND FOR JUST 20 SEC LIKE THE SOUND THAT IS MAKING A TRAIN WHEN IS STOPPING ....SOUOU . THE ONLY TECNICAL DIFFERENCE BETWEEN THIS UNIT COMPERATIV WITH THE OTHERS UNITS IS THAT IN THIS UNIT THEREA ARE ONLY THE IMPORT WINDOW (BRINGING THE AIR ) THE OTHER WINDOW /OPENING IS OUTSIDE THE WALL FOR THE ECONOMY OF SPACE BEST REGARDS DR DIAMANTOOYLOS drdiamantis@hotmail.com
3 Suggested Answers
farfield
  • 462 Answers
SOURCE: will you tell me the electrical diagram of 12
Remove a door Usually the wire diag is on a cover. I do not under stand why you have so many model numbers. Unless its a generic label used on all the models. and in this case the diagram will most likely be for all them too with foot notes showing the differences. If this helps PLEASE GRADE ME ACCORDINGLY. IF not I need more information.
Posted on Mar 02, 2009
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Have you found the problem with ya A/C yet PD with the U4 code, if so what was it.
Posted on Jul 27, 2010
How can resolved PJ error in daikin vrv 2
PJ is an error that has to do with the outdoor unit not matching the indoor unit. This means the outdoor board thinks it's a 2 ton unit and the indoor thinks it's a 1 ton unit. (Just throwing those numbers in)...but, the indoor is not matching the outdoor. You need to read the manual and go through the setup process.
Jul 30, 2017 | Heating & Cooling
Daikin vrv system error code a3
hi, A3 Indoor Malfunction of drain Level control system.
Air Conditioning Fault Codes
Feb 24, 2014 | Heating & Cooling
U3 problem for vrv daikin
U3 Is a failure to carry out check operation, transmission error
This is a self diagnosis the unit does before starting to ensure both PC boards are communicating with each other. Check wiring is correct on the units, usually means one PC board has failed
Oct 28, 2013 | Daikin BRC2A71 - Simplified Individual...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Red light blinking and no cold air provide
Indoor fan motor is not running. Check and replace it.
Aug 17, 2012 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
My daikin inverter does not turn on. when i press on on the remote, the flaps open all the way down then close. the green operation light is flashing.
Seek a refrigeration mechanic. With out looking at the unit it is to pin point problem.
More than likely a PC board issue on the indoor or outdoor unit. Does your remote control give you an error code. If possible look at the users manual on how to get the remote to give you the error code.
Nov 26, 2010 | Cfm Daikin R410a Split System Air...
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Will you tell me the electrical diagram of 12 floor standing vrv daikin?the model of indoor units are fxlg63mave and the outdoor units are rxyq12p7ylk rxyq10p7ylk rxyq8p7ylk
Mar 02, 2009 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
