Question about Braun Flex XP II 5790 Electric Shaver
Braun 5790 Contour shaver flip up trimmer has come apart and there's a metal clip that fell out. How do I reassemble this?
  • 3 Answers
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
VtToolMan
  • 704 Answers
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
Testimonial: "very helpful"
brector3
  • 1602 Answers
SOURCE: My braun Contour 5790 does not charge in either
It my be the batteries but they usually go bad very gradually and you should still be able to use it from the cord. It sounds more like a problem with the circuit board.
I suggest that you first find out if it can be covered under warranty. You can call an authorized service center at 847-869-7755. They can tell by the date code on it when it was made. If it was made less than 2 years ago. you shouldn't need your receipt.
Posted on Jan 26, 2010
Testimonial: "Thanks for the help. I will call the telephone number. Rich"
  • 185 Answers
SOURCE: how do you get the braun 5790 razor apart?
Try this page,. It should be helpful.
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters.html?cat=135
Good luck
Posted on Jan 30, 2010
brector3
  • 1602 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
Where do i buy repolacement batteries for my braun contour 5790 electric shaver?
Use this link: http://www.braun.com/us/male-grooming/maintenance.html
Jul 15, 2014 | Health & Beauty
Braun contour 5790 battery replacement
try this link: http://www.braun.com/us/male-grooming/maintenance.html
Jul 15, 2014 | Braun Flex XP II 5790 Electric Shaver
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
My former razor, Braun 5414 would take 110-240AC as well as 12 DC. Now have Contour 5790, and want to know if itcan also use12 volt DC.
According to the Braun manual for your 5414 Contour, the specs for charging are printed on the electric shaver cord plug. (it's REALLY small print, so I'd get a magnifying lens to look at it!)
There isn't anything in the manual about the multiple voltage for charging the shaver, so I'd have to defer to the Braun (Gillette/Proctor & Gamble) customer service folks to make absolutely certain of what can and can't be used as a charging voltage before trying.
Here's a link to your manual, in case you're missing yours.
http://www.retrevo.com/d/ds/progress?doc=9142c4ae65df1746d12fc67fdc01df52
You can ALSO reach the Braun Customer Service folks by calling them at 1-800-BRAUN 11 (1-800-272-8611)
I hope you find this Very Helpful and best regards!
Oct 06, 2009 | Braun Health & Beauty
Braun shaver model 5428
I have fixed mine. the pointy end fits in a hole next the the part that actuates the long hair trimmer (on the trimmer). this points out to the side of the shaver, and the rounded end fits into a little slot on the body of the shaver, slightly lower than the track the long hair trimmer slides along, and towards the top.its fiddly getting it all back together, but its perfect now. Dead pleased.
Sep 08, 2008 | Health & Beauty
Where do I buy a replacement side-burn trimmer for the shaver?
The trimmer is sold as the back housing assy. I have them in stock. Please call me aty 1-888-643-9806 to order 1. I will tell you how to get the shaver apart to replace. Ask for Action Mike.
Jun 05, 2008 | Braun 8585 Electric Shaver
Device will not charge...
Just take it back to the store where it was purchased and they will trade it for a "New" (Not broken) one. It's the holiday season and you have a week or two, on returns. There is a two year warranty on the product ( Braun 5790 ), if you want to go that route. You can contact the company @ 1-800-BRAUN-11, the person, "I" spoke with, was very nice and didn't act like I was a problem and she didn't try to just blow me off.
Good Luck-
Nov 20, 2007 | Braun Flex XP II 5790 Electric Shaver
Braun Flex XP II 5790 Electric Shaver Logo
181 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
