I have a divinci dv-6030 surround sound base box. the main power cord has been cut off. i wish to reattach another outlet plug onto it, only problem is the plug wire coming from the 6030 contains 2 insulated wires, a brown one & a blue. as most power cords are black/white (& green, if a 3 prong) this has left me a little confused. any help on which is the hot color would be greatly appreciated. thank you, drew
    Habit-Forming:
  • 24 Answers
Brown is usually black and blue is red and in your case most likely red/blue is white. In europe brown is used instead of black.
Posted on Jul 17, 2017
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
  • 744 Answers
SOURCE: Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Posted on Apr 13, 2009
jsrock516
  • 5911 Answers
SOURCE: I need to change the dryer power cord on my Amana
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Posted on Jul 17, 2009
RixsFixes
  • 2200 Answers
SOURCE: I would like a manual for a Divinci DV 6030 system
Hi
You can download the Owners Manual and additionally get the actual installation manual from this link
http://www.divincisound.com/other2.htm
Hope this helps. Please do rate this answer. Thanks.
Posted on Sep 01, 2009
  • 8404 Answers
SOURCE: 120v hot tub wiring diagram
I would expect your tub is either 110 or 220. Currently you are set up for 110. Based on that ... you disregard the red wire.
If your tub can run on 220, you should run it on 220 as this is more economical.
You should probably have an electrician check this out and make any changes to assure proper and SAFE operation of your tub. You are using a GFI, correct?
Thanks for your interest in FixYa.com
Posted on May 16, 2010
How do I get the vacuum to turn on now?
Just to cover all bases, have you tried an outlet on another circuit? It sounds as though the vacuum (motor perhaps) shorted and tripped the breaker.
Nov 15, 2017 | Miele Vacuums
Need Phillips SRU6061 universal remote setup code for DiVinci D7 surround 5.1 ch
0937.0918.0973,0983,0000 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 17, 2013 | Televison & Video
I have a 3M STV Digital 6 surround sound system. The receiver is emitting a loud buzz the minute I plug it in. The only way to eliminate the buzz is to unplug the power cord. Any suggestions to remedy this...
A loud hum could be caused by an Earth loop. This is caused by connecting various stereo equipment into different mains power outlets.
To overcome this problem, use a power board and plug all the stereo equipment into this single power board.
May 27, 2011 | Audio Players & Recorders
I need a code for divinci remote model #DV-6030
My husband and I paid $50 for our system WITH A CONTROL. After reading that a lot of people didn't even get a remote and paid $300 makes me realize we got a pretty good deal. My 1 year old ruined it by covering it in saliva. I went on DiVinci.com but they don't provide a code or a phone number to call. So far no luck. I also saw they have replacement remotes for this system on Ebay... After reading about possible scams I wouldn't risk it. If you find anything I would a appreciate a post with a solution!! Good luck to us all
Sep 15, 2010 | Televison & Video
Hi
Sep 01, 2009 | Audio Players & Recorders
I lost my remote for the divinci d-6 surround sound, can i use a
i have the same problem but mines a d-7... i threw it at my brother ;)
Jul 17, 2009 | Audio Players & Recorders
WHERE DOES THE SUBWOOFER SPEAKER CABLE ATTACH TO ?
the incoming wires go to circut board.the sub wires will also come from the circut board im sure if opened you will see where they were solidered on
Jun 10, 2009 | Audio Players & Recorders
Uniden Power Max 5.8 - (TRU8880-2)
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
50 people viewed this question
 Grubhead
Grubhead
