My webcam wont work and i dont know the model it has six lights on it and a built in mic
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
Hi Tommy,
Go to your manufacturer's main website, and look for the technical/downloads section. Pick out your series computer and model number, then drill down to the installed equipment portion. When you get to the download section, you should see a list of typical components installed on your machine. From that point you may see one or two drivers for your particular Webcam. Download, and try. You should hit the correct model in a jiffy, and get it going...unless there is a physical defect with the camera. Let's hope the correct driver will fix your problem.
Also, Dell has a great area to actually enter your "Service Code" (on the bottom of their laptops) and see all the original components installed on your laptop. Gateway and HP will offer excellent help in these areas also.
Let me know if this helps you solve this problem. Thanks.
Regards, Bill
Posted on Oct 02, 2010
People i call cannot hear me
I assume your webcam has a built-in mic, otherwise lack of mic is the issue. Assuming you have a built-in mic try the step-by-step procedures in this webcam technical support article to get your webcam mic working. It has screen shots and guides you through the process.
Aug 22, 2010 | Logitech Webcam
Does the acer 5517 have a built in mic
Acer 5732z has a webcam but there is no built-in mic, you need to use the external mic connector (pink/red).
Feb 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
The sound is not working on my webcam, i have made sure that the driver is installed and everything, and that it is enable in the properties of the volume control panel.
Try setting up your audio from the beginning - I dont know your computer set up ( desk top with add-on speakers or laptop with built in speakers or your OS ) So I will give you a general example using :-
Laptop with built in mic x webcam with built in mic x Vista OS x Yahoo Messenger
If you have an earlier OS, you may have to access some of your hardware ( speakers and mic ) from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Dec 01, 2009 | Gear Head WC330I Webcam
Webcam recorded audio have interferance
make sure you only use 1 mic .if that dont work try pluging in a diff mic. most laptops have built in mic's it might be bad disable it in control panel and use new mic
Oct 07, 2009 | Toshiba Satellite A135-S2386 Notebook
My built in webcam wont work on msn
Test it here by clicking 'allow' in top window
http://www.testmycam.com/
If it works OK you need to configure it to WLM
Open menu > Tools > audio and video set up - set mic as default if it has built in mic and test audio > Next - set webcam as default and tune picture using settings > Finish
Sep 29, 2009 | GE MiniCam Pro HO98756 Webcam
How do i get my asus k50 webcamera to produce sound?
webcams dont have mics...the mics are built into the bezel around the screen and are controlled by the sound drivers. You have to use the webcam software to link the sound drivers to your webcam software so the two work together when you are on video messaging. Check into the webcam software documentation. I know that when I was setting up my webcam in Gmail, it was linked to the sound drivers automatically.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
Does this webcam have a built in mic
no there is no inbuilt mic in the webcam. source of information is http://www.dealtime.com/xPO-Ezonics-EZCam-EZ-317.....thanks for using fixya! please dont forget to rate my solution.
May 30, 2009 | Ezonics EZCam EZ-317 Webcam
Dont Know How To Turn On Microphone on webcam
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Dec 25, 2008 | Logitech QuickCam Communicate Deluxe...
Cant get webcam to work dont have cd help!!
you can download them from here:- http://www.mic-innovations.com/Support/Drivers.aspx Please dont forget, your rating is important, thank you
Jun 05, 2007 | Micro Innovations MCNIC50C Webcam
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
