Question about M&S Systems Local Audio Input Module - Xtreme Digital Music System Shelf System
I have a panasonic sa-pm45db hi-fi. have lost instructions and can't tune or store radio stations. how do you do it? many thanks
Hi I have a Panasonic SA-PM200 mini hifi how do tune the radio stations
Make sure that you have the source set to FM or AM and the correct sound quality mode selected. Then press the Search track (fast forward or fast reverse) buttons on the remote. (These two buttons have the << or >> symbols and are on either side of the Stop button on the original remote.) If you press and hold the button, the radio will scan the frequencies in that direct until the next station that can be tuned in. The Skip buttons ('<< or >>') only goes to preset stations. As far as I can tell, these buttons are not on the main unit.
The remote is listed as part N2QAYB000639 . A replacement remote is available at several online locations including amazon.co.uk . See https://www.amazon.co.uk/Panasonic-N2QAYB000639-Remote-Control-SCHC15EBK/dp/B00H988QAM . The manual is available online here: http://panasonic.ae/en/manuals/SC-PM200.pdf . The SC-PM200 is the model for the entire system; SA-PM200 is the main unit. See section 7 for the radio tuning information.
I hope this helps.
Oct 28, 2016 | Panasonic Audio Players & Recorders
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Kx50looking for a user manual for a panasonic audio system SA-AKX50
Panasonic are very good at supplying their own as a free PDF for most models. Visit your area Panasonic Website and put in the model number and see if it comes up. If you can't find ask them.
Oct 28, 2015 | Panasonic Audio Players & Recorders
I have and older unit a pioneer VSX 3800, how do you program the radio channels, is there a manuel for these unit i can get sent to myself
Hi.
You have a digital display pioneer receiver and you would like to know how to store radio stations.
  • first tune your radio to your selected radio station
  • next see if the receiver has a button marked memory, and it should have buttons marked 1 2 3 4 5 6 etc
  • After you have tuned in to your selected radio station, if it has a button marked memory,
  • Press the memory button, then press and hold 1 for a few seconds and that should store your selected radio station to preset 1
  • Next, tune in to another radio station and store it by pressing memory then 2 and that should store it in location 2.
  • If your Receiver doesn't have a button labelled memory, and simply has the store 1-6 etc buttons then ,
  • Tune in to your radio station , then press and hold 1 for a few seconds, it will probably flash a few times until its stored in that location 1
  • Next, tune in to another radio station, then press and hold 2 and that should store it in location 2.
  • repeat.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Pioneer Audio Players & Recorders
I have lost my instruction manual so now i do not know what buttons to press in what order to save my tuned stations
grahamkinger,
Great model, I had one in the 80's!
I attached a link below to the user manual.
1) Tune to the desired station to be stored.
2) Press and hold the enter/clock button.
3) While holding the enter/clock button, press the preset of your choice.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=SRFM32®ion_id=1
If this helps, please rate the answer, thanks.
-Chris
Jan 09, 2011 | Sony Walkman SRF-M32 Radio
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
How do I preset radio stations on my hi-fi system?
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Apr 28, 2009 | Denon DRA-375RD Receiver
Preset channels on Panasonic car radio out of tune
this is simple enough to do, just find the channel you want to save, then press and hold a number u want to save it to!
i.e No. 1 - 96.9Fm
hope this helps
Feb 15, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
How to store a radio station
On most Radio Systems do the following:-
use the tuning buttons, + or - to find the wave length for the required radio station
Once you can here the station, press the button for the number where you want to store the station and hold it down until you here a beep
Do the same for other radio stations on the other numbered buttons
thanks HPC
Jan 17, 2009 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Help with storing radio stations
Ergh, you might want to explain what KIND of system it is if you need help!
Usually if you have a PRESET button on your system, just tune to the station you want, hold the preset button and it will save the station...or ask you which slot to use (use fast forward/rewind or any other arrow key to change the slot) and viola! And if you have numbers (like in a car for example) just tune to the station and press and hold (for example) the 1 button and it will store the station.
Hope it helps a bit.
Sep 16, 2008 | Audio Players & Recorders
M&S Systems Local Audio Input Module - Xtreme Digital Music System Shelf System Logo
247 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
woodzowl307
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
