Question about Garmin nuvi 200W GPS Receiver
Hi,i wanna know what software must i get so that i see my speed while driving when i set a location. the newer models show it. but mine ONLY shows it when i view the map. Please advise me thanks alot..
  • 504 Answers
You cannot change the features of your unit. Newer models have different features that CAN NOT be added to their predecessors. I'm sorry, but your unit will only ever show your speed when you view the map.
Posted on Aug 21, 2010
How do I replace the speed sensor on the Landice L9 pro sports cardio trainer?
the speed sensor is in the front drive wheel. it is a sensor located on the left-hand side you will see a wire going to the sensor. then a magnet is on the wheel and when it passes by you get your speed.
Oct 16, 2016 | Landice Exercise & Fitness
Hi, how can i repair caller id , euroset5020 it disp((((((0))))).
Just had the exact same failure on a vtech phone (except, when mine failed, it would only show "incoming call" instead of the Caller ID.
Ended up buying a newer model. The newer model has call block which is a dream come true with all of the robo calls nowadays...
Nov 05, 2015 | Lands Phones
Drive replacement and rebuilding Raid 1 on a Dimension XPS Gen 2
Did you format the new drive? Formatted size must be the same or bigger than remaining drive.
Mar 07, 2014 | Dell Dimension Computers & Internet
R320 CDI 2007 model does not show the time. I know how to set the time using the buttons. But it doesnt show anywhere. How do i select the option to show time while driving. Please note that the Command...
Normally, the radio needs be on to show time for it to be set. Mine is that way. If you have the radio on when yor trying to set time and it won't show time, I don't know the answer. But mine does show time when radio is on to set it. Then radio off and time displays when switch is on.
Nov 12, 2017 | 2007 Mercedes-Benz R320 CDI
My 1300 doesnt seem to calculate trip data such as time or average speed, miles, etc. stays on zero. does show max speed.
is it set in similation mode?? try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update
Dec 01, 2009 | Garmin nuvi 1300 Car GPS Receiver
Can a modem die in a laptop? mine just stopped
Yes modems can go out in laptops.most of the newer models are replaceable,and easy to install.See you bought a dell.Try to call ther parts division and order a replacement,go to there web site and look up your laptop it should show how to install it,if not repost it and i will help you reinstall it.Who knows you may be under warranty and get a free one .They have fast shipping.Have a nice day !!
Nov 10, 2009 | Dell Latitude D820 Notebook
When i link between cam and pc it cann't show
Hi Masryman
I aassume the pc is not recognizing the camcorder when connected thru Firewire? I am not familiar with that model but some other Panasonics show the same problem. One suggestion that seems to work is to connect the camera to an external Firewire hard drive and then connect the hard drive to the pc.
Not elegant or logical but it seems to work.
Sorry I can't help more,
Cheers
Martin
Oct 30, 2009 | Panasonic SDR-H40 HDD Camcorder
Carl lewis treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Jul 06, 2009 | Exercise & Fitness
Who to overclocke my motherboard'z FSB or my processor?
Hello.
It is not save for your system making it work faster by overclocking it.
Some times it works fine just using the right cooling methods, but some times its leads to system freezes, crashes and even to permanent processor damage.
So i advice you to keep that in mind.
If you want to proceed anyway.
- In newest computers you will find an option to set the processor speed to automatic( system recognize the cpu speed) or manually, in the last one you hve to set the RATIO( Processor speed divided by FSB speed), this means:
- The FSB of your P3 Motherbord (133 Mhz) x 7.5(ratio)= 1Ghz
- In older motherboards the speed option is set using jumpers
configuration in the Board, inthat case you will have to use the motherboard manual( some boards have printed tables) to show you the config.
Note: if your motherboard doesn't show you the RATIO you need is because it doesn't support that speed.
Good look.
Jul 04, 2008 | VIA C3, 800 MHz (VIAC3800) OEM / Unboxed...
Garmin nuvi 200W GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
