Question about Fuji Cameras
I was taking pictures outside using a tripod mounting and had my Fujifilm FinePix S5000 on in photography mode - Auto mode. Upon placing the tripod for a new photo, I observed that the LCD monitor had turned white with intermittent horizontal flashing black lines. The view through the viewfinder is also white but without the black lines. When a photograph is taken the image is white. I should point out that in Playback mode I can view previously taken photographs perfectly on both the monitor and viewfinder. Perplexed!!
  • Anonymous Mar 11, 2014
    citreon berlingo 1.9 won't start, new battery
  • 10,594 Answers
It seems ccd imager chip problem, ccd imager chip is electronics device that converts an image into electronics signal. It is located at end of lens assembly in camera.
CCD imager chip will be replaced to get correct view in camera mode to take picture.
Local camera repair shop will help you to replace this part as camera will take apart in details and soldering work is needed to replace defective chip.
Hope these info will help you.
Thanks.
Posted on Aug 21, 2010
Why does my fujifilm finepix s5000 camera say memory card is full when it is empty ?
RAW format uses enormous file sizes. Smaller memory sticks will be used up with just one single picture when using the RAW format. You're confirmed this when you said it only happens when you use RAW format. You need to use a larger memory stick, if you want to use the RAW format.
Jul 12, 2014 | Fujifilm Finepix S5000 Digital Camera In...
Cannot focus on moon with Fuji HS30.
I suggest trying a higher ISO setting and using the tripod. My moon shots look just fine from the HS30exr.
Jan 05, 2013 | Fujifilm Finepix Hs30exr black Digital...
Fujifilm s5000 battery door broken
g'day
i broke mine a couple of years ago and fixed it by drilling and tapping two holes to suit 6-32 x 11/4" bolts as shown in the attached photo... one of the holes had to be enlarged to suit 6mm x20 because the thread is in a very flimsy area and had stripped
BTW the battery cover doesnt have to be removed from the camera as is shown in the photo! the photo was taken after i disassembled the camera for another repair
it works well with a couple of provisos...
1- the bolt heads may get in the way of mounting the camera on some tripods without modification
2-not as quick to change the batteries
3- dont screw the bolts down too tight - or the threads will strip
before this method i made a metal plate, the same shape as the base of the camera and used the camera tripod socket to attach it... thus keeping the battery door closed [ the advantage of this was that i could drill and tap a thread to attach the lot to a tripod - and the tripod mounting hole could be ia the centreline of the lens - making panoramas easier]11_28_2011_10_48_37_am.jpg
Nov 22, 2011 | Fuji FinePix S5000 Digital Camera
I have a FUJIFILM Finepix S1500 digital camera and I love it! But i find it hard to use the macro settings and how to get really clear shots! Any help? :)
Macro photography usually requires a steady camera. This means you need a tripod for really clear shots and you need to be within the distance range as outlined in the owner's manual.
Oct 28, 2010 | FUJIFILM Finepix S1500fd Digital Camera
Fujifilm S5000 !hand error
It it in normal shooting mode? The hand means the shutter speed is too slow to hand hold the camera.
Jul 24, 2009 | Fuji FinePix S5000 Digital Camera
Fuji Fine Pix s5000-Horizontal lines with purple coloring mixed
not a software issue it is
CCD FAILURE !
CALL Fujifilm they will do it FREE it is a known problem in thousands of camera i got my S5000 with same problem repaired FREE from FUJI just call them
BAD CCD
RATE ME WELL !
May 27, 2009 | Fuji FinePix S5000 Digital Camera
Flash button won't select mode.
you cannot set anything on auto mode! The camera sets itself automatically. try taking shot(AutoMode)in dimlit area or no light at all. If it's taking shots and flash isn't firing, your flash bulb is already busted! I suggest you buy a separate flash unit (they cost the same as replacing parts and service fee), a cheap one is comparable or works the same as the costly one, if you know how to set up on manual mode ( they call it compose or advance or creative mode!)
Sep 03, 2007 | Fuji FinePix S5000 Digital Camera
Camera turns off
CCD sensor is faulty and the sound you hear is camera switching off lens after no signal from CCD block is delivered to the main CPU. CCD has to be replaced and should be done free of charge if the camera is newish and has not been abused ( you bought it with poorely manufactured CCD sensor which should last 15 years ).
Jan 06, 2007 | Fuji FinePix S5000 Digital Camera
Considering a Fujifilm s5000
Does this camera have the ability to zoom while in recording mode?
Sep 04, 2005 | Fuji FinePix S5000 Digital Camera
Cameras Logo
65 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
