Question about Garden
How do i remove lexshaft from engine of a roybi weedeater.
  • 260 Answers
You will need to separate the motor from the shaft. Once this is done the flex shaft can be removed from the tube.
Posted on Aug 21, 2010
The pull cord on my Roybi rtl30ces will not retract. How do I access to repair?
Hi Kathy - more likely than not there's a little "tab" on the end of the spring that slips it to a tab in the plastic to maintain spring tension.
These break off fairly regularly and you can easily bend the spring steel to a 90 degree to "fix it" and place it back in the tab.
I've included a teardown / rebuild video that should be very helpful when repairing your weedeater - it's a "generic" ryobi video but they're all really, really similar.
Don't be intimidated - they're super easy to work on! How to Fix the Starter on Ryobi Trimmer
Sep 03, 2016 | Ryobi Garden
Unsieze a weedeater motor after using regular gas
Even if you are able to "unseize" it, it may not run afterwards. The reason you NEED to add oil to the gasoline is because that is the only lubrication the engine gets! You can try to unseize it by removing all of the remaining gasoline from it and putting in ONLY some 2 cycle engine oil. Then you will need to attempt to turn the engine shaft back and forth using the weedeater feed spool as a lever handle. IF, and I say if it breaks loose you may not have sustained alot of damage. If it doesn't...
Jan 10, 2013 | Garden
Detachable shafts will not go on.
check flex shaft,inner part of the larger housing,be sure the end is not damaged.....also check flex shaft end from the engine side,may have damged coupler
May 01, 2012 | Husqvarna 128 LD Weedeater
I have an weedeater 22"
check the fuel
if old -- TOSS it OUT!
Fuel quality sucks and has ethanol,. which eats rubber hoses and leaves residues through the carburetor and more,. try wiggling the needle valve without turning it - if otherwise do not loose placement of where the needle valve is setting currently if you do turn or remove the needle valve for inspection..
Also try some starting fluid to blast it a bit,. be careful if it is 2 cycle as you need oil to run the engine too!
Best regards
ck
Aug 18, 2011 | Garden
I need to remove the clutch assembly from the shaft. Is there a special tool or technique I need to know about?
You will need to remove the bolt from the centre of the centrafugal clutch and remove it from the shaft with a flywheel puller. Good luck!
Aug 11, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Weedeater Hedge Trimmer
It's a 2-cyle engine. The oil is in the gas.
Jun 06, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Removing spool on weedeater SG11 Electic
Pull on the tap head. Straight out. Hard. Here's the Weedeater manual. http://72.3.225.179/manuals/545117522e.pdf The spool should just pull out, its held in by 2 clips, royate it till it pops up then pull it out, with a wiggling motion, Grasp firmly and pull straight out....per tech support from 800 number on machine.
May 14, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
How to replace recoil assembly on roybi 780r
have ryobi 780r and primer bulb won't show fuel pressed and fuel comes out of fuel cap,i have pressure in fuel tank. it ran 2 weeks ago great?
Jul 01, 2009 | Ryobi Garden
Weedeater or trimmer
sounds like the carb is still not right or the unit is low on compression - you need 90 lbs min
Oct 12, 2008 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
