Question about La Pavoni Europiccola EPC-8 Espresso Machine
Hi i've got Pavoni gold 8 cup. It just shut off on the middle of getting hot and ready. the power light went off and now there is no power. i checked it on several outlets, no go. also took bottom off and all wires seem to be connecting properly. any help would be much appreciated. thx--Chris
  • 19,396 Answers
Hi.
If it shuts completely off, then the controller board is faulty. That is probably the only part that can cause shut down after machine has been connected and had been on for a while.
Posted on Aug 21, 2010
Fuse keeps blowing La Pavoni Europiccola 1996
Hi That's a short it's all it could be isn't it. Plug? lead? water or damp in the base? try slipping the black base off you will need a security bit to get it off or at least mine does its a t bit with a hole in the middle I think, have a look for water that might be shorting it out also try it in another socket , you never know.
Best of luck.
Feb 28, 2014 | La Pavoni Coffee Makers & Espresso...
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
May 13, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
I've a smart UPS 1000VA SU1000INET I've had new batteries fitted. I put on to charge everything seemed ok. Went back to it about 2 hours later to find the 6 middle lights flashing.
Hi Ian,
Time for a new unit. Some component on the board level is malfunctioning.
If you need UPS, Surge, or Power Related help contact:
Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
Apr 15, 2012 | APC Computers & Internet
Just purchased the Elite Keurig and followed the setup instructions. On step 8 it says to press the flashing blue light, both lights are lit up with a solid blue, neither are flashing. I went ahead and...
This should be a relatively simple solution. 1. Ensure that water is in the tank and filled to the top. 2. Raise the lid of the machine with the silver handle and insert a K Cup or just raise and close for hot water. 3. Blue light should now be flashing to indicate the machine is ready for use.
Apr 29, 2011 | Keurig Elite B40 Coffee Maker
Hi can you tell me how to reset the safety thermostat on a La Pavoni EBR. The instruction manual tells you to do this but does not show you where it is or how to do it! Rob Burd
Hi Rob,
Open the top of the machine. On the heater element you'll see 8 cable connection: 2 on one end, 3 pairs on the other. The safety reset thermostat is on the middle of the 3 pairs (easy to spot the other 2 is flat, the middle one has a 2mm part sticking out). Remove that pair of cables - just in case - and push that button in. You'll hear a clicking noise. Connect the two cables back to the element and follow the "starting up procedure" from your manual. If you did everything correctly the machine will start to operate. Turn it off and put back the top. That should be it.
Dec 09, 2010 | La Pavoni Lusso PL-16 Espresso Machine
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
Nov 22, 2009 | Saeco Vienna De Luxe Espresso Machine
On a La Pavoni europicola which way do the piston seals get installed, both the same way or opposite to each other?
Normally on lever machines the top seal sits with the cup area(slash in gasket) facing up and the bottom facing down.
May 16, 2009 | La Pavoni Europiccola EPC-8 Espresso...
First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Professional, Chrome, 16 cup capacity Europiccola
You have to take a screwdriver and try to bend up the platic, be careful so you not break it.
Aug 20, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni Europiccola EPC-8 Espresso Machine Logo
29 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
matt
matt
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
