Question about Garden
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
  • 262 Answers
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Posted on Aug 21, 2010
  • cat_fan_ky82 Sep 04, 2010
    i too work with the same machine, bobcat 225g, used primarily for stick welding, at times it, set on run/idle, will idle as it should, but then there are times, when it is set to run/idle that it will idle down, then back up, back down, back up, etc., when it should just idle, for no apparent reason. and it is a gas welder, and no, it is not normal for one set on run/idle to continuously run when not in use, thats the whole point of the run idle setting, to save fuel.
  • john may Sep 18, 2014
    mine well idle upfor power tools but not for welding thn it trys to and floods its self out any1 no y?
Miller Bobcat 225G was sitting for about a year I put new gas new fuel filter new sparkplugs and cleaned out the carb it cranks good but wont start I have no spark to the spark plugs
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 08, 2017 | Bobcat Garden
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Welder won't speed up to weld ?
What doesnt speed up to weld? the feeder? is the wire burning back? are you getting any wire? this is gmaw / wire right? sounds like it may be running slow
Jul 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Won't strike an arc,fuses ok brushes and slip rings ok
check the wiring and terminals on the earth return wire. They can break away inside the clamp ends. check the wiring and the hand piece
Oct 07, 2013 | Bobcat Miller 250 Welder Generator 907212...
Will not strike an arc, but welding machine still runs good
Hi:
Probably your machines overloaded. Check your fuses F1 and F2 and if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Apr 21, 2011 | Bobcat Miller 250 Welder Generator 907212...
Bobcat welder will not kick down between arcs, its a model 225g
Simple first, make sure you have it set to auto idle
Dec 23, 2009 | Welding Tools
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Garden Logo
348 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
