Question about Home
Im forget my phone lok parowd four my telephone
  • 85 Answers
You can visit your mobile phone companys service center where they will reset your phone with softwares
Posted on Aug 21, 2010
Hi i have my memory card password forget
you can unlock your 2gb sd card..
1. Insert the sd card into a software phone. (eg. Nokia 6120c, 5800, 5233 etc..)
2. Select settings > data mgr > memory > options > format memory card..
Note- formating memory card will delete all datas in your sd card
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
Keep getting error code 388* when im faxing something
Pls do the following
Error Code:
388
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Have a 3010 SD and only line 1 rings, there are 4 lines.
The telephone has several capacities mentioned as four lines where each would have been networked a separate devices to attain voice communcations. The telephone service provider usually would request to either install at the location several beyound online jack to make possible several entities communcations. Also, the phone with several line becomes useful in situations where several office spaces require communcations sharing from the same telephone. Considering the number of lines that the telephone provider made avilable at the location, the telephone feature buttons can be used to select several lines of choice only that all four becomes tasked when four telephone connection jacks were established.
Feb 15, 2011 | Toshiba DKT 3010 Corded Phone
I have 6020 nokia mobile, and i inserted the pin code code incorrect more than one time. now he ask me to enter the puk code. what is the puk code and where i can find it??
Bhosdina navra betha phone ma ghoda na marta hov to, ghel choida, chodu madan choksi. phone lok karvo hoi to keyguard ma lok marai, nakar apdi gand ma lok marai... have maravo gand lok vagar.
Oct 22, 2010 | Cell Phones
Forget my telephone password
i cant remember my phone password
Jun 01, 2009 | Panasonic KX-T7730 Corded Phone
Sch-a650
I bealive you can use the last four digits of your telephone number.
May 14, 2008 | Samsung SCH-a650
Home Logo
21 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
