Uneeded system images
How can i delete two system images from operating system start menu, wich shows when I turn the PC on???
Help please!!!!!!!!
  • 156 Answers
Ok goto ... Start...control panel... system...Startup and recovery click settings... click Edit to edit the startup file and make sure there is only 1 of these lines... You have 2 of them... So delete 1...
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Posted on May 03, 2008
Boot Menu 'select a boot first drive' instead of safe mode
ok, turn on pc i am not sure what operating system you r on but you turn it on look for log off, or administrator u need to get on admin, when ur there delete the profile of the one who needs a password but you will need to be on admin and make sure the passworded one has been logged off, hope this helps, leave a message if u cant do it that way,, there's other ways, paul. just seen it, windows xp, ok turn off tap away on F6 or F8get to the part where it wants u to put pass in right click picture of the user log off then go in as admin
May 08, 2015 | Microsoft Windows XP Home Edition
I need key for driver restore
Davis,
You can restore the system to factory conditions by following the information below.
Dell Factory Image Restore The Dell Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu.
Start the computer and TAP the F8 key. Once the options appear on the screen you can choose Repair Your Computer and follow the prompts to restore the computer to factory conditions.
CAUTION:
This utility formats the operating system hard drive partition prior to restoring the factory image. This means data on that partition is deleted and cannot be recovered.
If the customer creates a second partition with a third-party utility, Dell Factory Image Restore is not affected as long as the image partition is not removed.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
May 07, 2015 | Dell Vostro 1000 Laptop
Windows wont boot
Hi Rajib Chakraborty,
When posting issues try to be a details as possible this help to solve the problem more quickly and you problem answered more quickly.
Below are some step you can take to try to boot into windows if this fail, please provide more details to problem you are having.
1. Boot from Last Known Good Configuration
If the PC is on first restart the computer by pressing[Ctrl][Alt][Delete].
When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
2. Use System restore
To use System Restore, first restart the computer by pressing[Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the singlebeep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs ' Accessories ' System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
Nov 11, 2011 | Microsoft Windows XP Professional
My wifes toshiba laptop was accedentaly droped and when she turns it on it shows the toshiba start up ... but then it goes blank and does nothing..how can i fix this.......
If you are getting startup repair option agian and again.then your windows os is corrupted and you need to reinstall the operating system.
you can try system restore...to go there
restart the computer..start tapping F8 when your computer boots...in advance boot option menu go to ..repair my computer...select the language as english...then enter your username and password..then choose system restore..you can try factory image restore but it will delete whole data and take the computer back to factory image
Aug 29, 2011 | Toshiba Computers & Internet
I put in a cd and it will not come up, not even under my computer will it show anything so dvds and cd will not do anything ,
For this issue please follow below mentioned steps-
Remove the modified registry entries. To do this, follow these steps:
  1. Click Start, click Run, type regedit, and then click OK.
  2. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  3. In the right pane, click UpperFilters.
  4. On the Edit menu, click Delete.
  5. When you are prompted to confirm the deletion, click Yes.
  6. In the right pane, click LowerFilters.
  7. On the Edit menu, click Delete.
  8. When you are prompted to confirm the deletion, click Yes.
  9. Exit Registry Editor.
  10. Restart the computer.
If you are using windows vista-
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, click All Programs, click Accessories, and then click Run.
  2. Type regedit, and then click OK.
    Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Hope this would fix the issue.
Mar 22, 2010 | Dell Computers & Internet
My desktop in Vista is MISSING! What happened?
hi
restart your system and keep pressing F8 key when the system is starting
then select "LAST KNOWN GOOD CONFIGURATION" using arrow keys and click on enter.
if this did not solve your problem then select
Safe Mode and click on enter then go to system restore and roll back your system to a point that was working properly
Dec 22, 2009 | Microsoft Windows? Vista Home Basic...
Recover deleted .GHO files
If you are seeing the file within the recovery software but it shows as 0 bytes then it was probably already overwritten on your HD. You should take a new image.
May 30, 2009 | Microsoft Windows Vista Home Premium...
Sony Cyber Shot 5.0 MP Zeiss Lens has distorted image
Please RESET camera by going in to camera MENU -> Initialize -> OK.
Camera will go to default factory settings and problem will resolve.
Feb 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Delete images tagged to mp3
you can go to folder options and select view menu >>> show hidden files and folders + remove tick mark from hide protected operating system files and u can go to the folder where your mp3 files are. and u will wind some pics. Delate them. If it dosen't work word please remind me ok.
Aug 31, 2008 | Apple iPod MA446LL/A MP3 Player
I cannot re install my start up bar the file display
In XP, go to Start > Control Panel > "Taskbar and Start Menu" and open it and you should be able to show and lock your Task bar aka "menu bar" from the Taskbar/Start menue options you'll see there.
Good luck.
Feb 24, 2008 | Toshiba Satellite A135 Notebook
49 people viewed this question
k24674
jasbo
jasbo
