Question about Panasonic DVD-RV32 DVD Player
How do I remove a stuck DVD on my Panasonic DVD-RV32? It plays well but it will not eject.
  • gchiaradia Aug 21, 2010
    I removed the 2 screws on each side but the clamp does not come out. Can you provide a screenshot?
    I have not been able to solve my problem. Please cancel this request.
  • 4,102 Answers
Hi, this is a very common problem, what happens is, the runners and the plastic cogs the draw runs on wear and then this causes it to lock in closed position.
now the only way you can get it open is buy using a strong knife or flat bladed screwdriver then when you press the open button try prying the tray open from either side, it may be quite stiff but once you get it open it shoud start working for a while until it locks up again, usually it will work ok for few weeks before it locks again.
their isnt anything you can do about it as the price of a new dvd player would cost as much as getting the parts replaced so its not financially worth getting it fixed.
so for now the best thing to do is try prying the tray open whilst pressing the open button after a couple of goes you should have it open, then it should work for a while, you may find it will never get stuck again but in most cases it will get stuck after a month or so and prying it open is the only option you have due to the costs involved in geting it repaired.
im sorry their is no long term fix but due to the cost its just not worth paying to have it repaired.
you may be lucky and it may not ever get stuck again so give it a try pry it open it may be a bit hard but after a couple of goes you should have it open.
use strong knife or flat bladed screwdriver and put the screwdriver in the side of the tray and then press open button or get someone else to press it whilst you pry the tray open from one of the sides of the tray.
let me know how you get on or if you need further assistance ok
Posted on Aug 21, 2010
  • Panasonic Master
  • 17,129 Answers
Thank God your set is working alright and the optical headd is in good shape.
1. Open the side screws and take the lid off after switching off and removing the plug.
2. Now you can see the disc mechanism with the CD inside. There is a cross bar across the DISC which is mounted by two crews on either side.
3. remove the two screws and the top clamp on the DISC wil come out. Now remove the CD.Sometimes you will need to remove the front panel .
4. replace lid back and test.
5. If the door wont eject then it is possible that the motor has jammed, the mechanism is jammed or the motor drive IC is faulty. Tighten the cords to the mechanism motor, solder the loading IC .If not you will need to replace this loading IC.
If the motor is turned a bit and if this works then the motor brushes are faulty . You might have to change to prevent futher repeat of fault.
I hope you will be able to get this sorted with the above tips & advice.
I am unable to play DVD's and receive error message HD7. How can I fix this? I own Panasonic DVD-RV32 player.
I think you mean H07 - this means the traverse unit (which contains the spindle motor and the laser in one assembly) has failed. The spindle motor is the most likely problem; unfortunately this is not repairable at consumer level, it would need to go to an authorised service workshop where the whole unit would be replaced in the player, which would include a brand new laser. The other snag is the cost - a new traverse unit can cost around $200 + labour (including alignment and firmware upgrades)!
Save yourself the agony, and simply replace the whole player - cheaper than repairs. The RV32 was not Panasonic's best DVD player model.
Mar 01, 2011 | Panasonic DVD-RV32 DVD Player
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
Panasonic dvd rv32 tv set at ch 00, play,sound only - no pic
you idealy need to use a scart lead from the dvd to the tv, then pick the "av" chanel it is plugged intoon the tv. You get a much better picture using a scart lead.
May 09, 2009 | Panasonic DVD-RV32 DVD Player
What formats will a Panasonic RV-32 read?
DVD only or mp3 or 4 but if you download a avi movie just get a converter avi to dvd.HOPE I WAS USEFULL PLZZZ RATE ME.
Dec 22, 2008 | Panasonic DVD-RV32 DVD Player
Rv32 dvd panasonic
Change The Region Settings.
It will play in Black and White If Its region 2. setup at Region 1 Or Vice Versa.
Mike @ Compurepair.
** Common Sense Comes as standard**
Feb 27, 2008 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32
dvd wil not function and screen display f498 i need help
Dec 01, 2007 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player Logo
152 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
