Question about Technics SA-DX950 Receiver
Technics sa-dx 950. F70 on display. ??? - Technics SA-DX950 Receiver
  • 4,234 Answers
This is a shorthand version of protect. See the link below. If you have more questions, please post them here and I'll respond.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Aug 21, 2010
What causes f70 code
This may be blown fuze. This is an informative forum. Read answer one-third down page. Hope this helps Technics stereo receiver F70 error code CK5 Forums
Mar 11, 2015 | Technics SA-DX750 Receiver
Technics sa-dx 950 Intermittent F70 Error
There should be removable access panels under the amplifier IC's that are attached to the heatsink. Remove these panels and inspect the solder connections on the IC's and the voltage regulators that should be mounted next to them. These have always had a tendency to go bad on Technics receivers. If you resolder all of these, you should clear up your problem.
Feb 26, 2015 | Technics Audio Players & Recorders
SA-DX750 error F70
I have a technics sa dx 750 receiver that cut...
Dec 21, 2010 | Technics SA-DX750 Receiver
I have a technics reciver SA-DX950 when i tnru on it say F70 on the display
problem is oxidation...Remove and clean the ends of cables with sandpaper slowly...there is slim and flat cable into the reciver (together with five cable)...specially remove it's socket and clean it...
May 09, 2010 | Technics SA-DX950 Receiver
F70 displays after about 5 min of use.
According to Technics reference manual, turn the unit off, unplug for a few, plug in, turn unit on. Consult your "dealer"(authorized repair person, i guess) if light remains on. But doesn't say what f70 means, or associated with.
Unplug and open up the unit, and check the internal fuses on the circuit board. Also check for proper speaker wire hook up. Re-seat the connections. Visibly check the speaker wire runs for shorts, cracked casing, cat/dog chewing. etc.
Hope this helps.
Apr 28, 2010 | Technics SA-DX750 Receiver
F70 on my reciever
Most likley it is in need of repair. I suspect the output IC. Check for bad solder connections on the IC and voltage regulators.
Remove the speakers and see if it still happens (it probably will).
Feb 11, 2009 | Technics SA-DX940
Technics sadx750 and says f70 and turn power off
Feb 27, 2008 | Technics SA-DX750 Receiver
F70
The system has detected a fault in the output section. How much are you asking of the system? Greater than 50%? That will push most systems to their limit in a short period of time...accordianman
Jan 14, 2008 | Technics SA-DX850 Receiver
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Oct 30, 2007 | Technics SA-DX750 Receiver
Technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Jun 25, 2007 | Technics SA-DX950 Receiver
Technics SA-DX950 Receiver Logo
1,351 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
