Question about Samsung Remote Control
My samsung have no pictrue
Can if fix my tv good sound but no pictrue
  • npwds Jul 14, 2008
    after hearing a"pop" ,picture went out but some sound ??
  • dallas1tx Dec 01, 2008
    I have a Samsung 52" HDTV 1080P tv. Sometimes after turning on the tv, blacks out the left side of screen after running for awhile . I turn off set and turn back on it will return to ormal screen. Sometimes it may do it 3 or 4 times thru out the nite
  • Samsung Master
  • 5,568 Answers
While only of historical value since both messages are so old, neither of you told us what model set you have. npwds gave us a small clue and even that isn't much use without knowing what kind of set it is.
Posted on Sep 22, 2008
Problem with LED TV screen
Hi Dale, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=cI2L61dzj6k
Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
May 11, 2016 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Tv randomly loses pictrue but not sound when watching
May be you need replace the lamp.
Time life aprox 3000 hours
If the picture is dark or don`t show picture, but you get sound, try replace the lamp
Is easy. You can find it in www.Amazon.com I recommend you buy Electrified brand.
Sep 16, 2011 | Televison & Video
I had my Vizio VO42L fixed last year because the power wasn't working. No backlight... it wont turn on at all. This time it turn and has sound but no picture. What part(s) do i need to replace?
Tv turn on now,have a flashes a picture only a few sec.than dies and have sound left only?Yes,than those 2 long boards to the left and to the right call the LCD inverter boards are dead.These 2 long LCD inverter boards,job are to help the LCD screen panel to have a backlight to produce a pictrue.Tries websites like Shopjimmy.com.Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Dec 08, 2010 | Vizio VO42L 42 in. LCD TV
The tv continues to click but has no pictrue
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Aug 04, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Jan 30, 2010 | Samsung HL-P6163W 61" TV
No sound
check the chroma section the where the sound section is attach flyback is only for picture and fucos.try to resolder the ic having 72pin.check also ur speaker.sometime there is a capacitor near the the pin 53 replace that.
Sep 12, 2009 | RCA F36650 36" TV
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv use 3.5mm j. it only has sound when I use input and select AV3 but...
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Aug 08, 2009 | LG 42LG30 42 in. LCD HDTV
No pictrue
Is the LED light purple ?
I have only read bad things about this model. Here are some of the things I have come across. Try this first. With the TV on, unplug it, wait a few seconds an plug it back in. You may also turn off the energy saving mode.
Beyond that the problem could be one of four problems;
1) Bad cable connection to inverter board. Make sure all cables are firmly seated.
2) Inverter board is bad.
3) Power to inverter board is bad.
4) CCFT(cold cathode fluoresent light) has problems.
Mar 08, 2009 | Westinghouse SK-32H240S Television
Samsung Remote Control Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
