Question about Tomtom GPS
ERROR: DesktopLib/DeviceItemScan/Error: Error during scanning for navigation items HomeBase/IO: Error reading file: E:\North_America_P\Safety_Cam_US_Canada_TomTom.ov2 @ .\portable\cfile.cpp(1938) .
Can a New York card be used in Florida ?
Depends on the make and model. Garmon splits the US up. The chop of California for some reason.
City Navigator North America NT Lower 49 States Garmin
This one does all of North America, so check your maker.
https://buy.garmin.com/en-US/US/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt/prod1456.html
Dec 02, 2015 | GPS
IO error
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output
(I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
Nov 25, 2012 | Western Digital WD5000AAVS 500 GB SATA II...
Is there any updated map for streetpilot 2620 since 2008?
Yes. There is one more mapset and then there will be no more for us using the StreetPilot 2620. You are looking for the disc set North American Navigator 2009. Make sure you do not purchase the NT version. I found the item on EBAY for $81and purchased it and it worked just fine. The 2009 is the last compatible map set that Garmin released for the 2620. Be certain that what you purchase includes that unlock key otherwise you will spend another $75 on that at the Garmin Unlock Site.
Here is the link that is good for a few more days, however, may relist it. The seller is yumelectronics and the search term is 2009 City Navigator.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390193775928
Here is the search for EBAY:
http://shop.ebay.com/i.html?_nkw=city+navigator+2009
Here is the item on Garmin's site:
https://buy.garmin.com/shop/shop.do?pID=8465
Listed as:
City Navigator® North America This product has been discontinued but is still available for purchase.
It is $99.99.
Good luck, and let me know if you have any other questions.
May 11, 2010 | Garmin StreetPilot 2620 GPS Receiver
When i try to backup to my computer: Following Error Occurred: ERROR: DesktopLib/FileCopy/Error: An error occurred. Unable to create the files required to copy this item to your computer. @...
When TomTom Home installs, I believe it either also installs, or needs to have installed, a copy of the Visual Studio Runtime (a 'C' language runtime from Microsoft). Also, your computer needs to have JavaScript enabled in the browser.
Check to see that both these required items are installed. It is beyond the scope of this question to tell you how to do that, I'm sorry.
Oct 19, 2009 | Tomtom XL 340S Car GPS Receiver
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
Sep 04, 2009 | Garmin iQue 3600 GPS Receiver
Need help unlocking maps in City Navigator NT North America.
I turns out that the unlock code was discreatly printed at the bottom of a yellow piece of paper in the packing.
Mar 21, 2009 | Garmin zumo 550 GPS Receiver
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
2005 honda pilot with navigation, i purchased this unit from the usa and imported it to canada. navigation system doesn't work, where is the navigation disk slot located and is there a disk for north...
same problem, disc is located under passenger seat, talked to honda canada , alpine and honda usa, they dont make a disc for 05, couldnt get nav in 05 cannadian pilots , they dont even make north america disc just stricly usa maps
Jan 19, 2009 | 2005 Honda Pilot
GPS Logo
218 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
