Question about Bosch Axxis WTA 3510 Electric Dryer
Dryer Bosch WTA3510us. I need to know how to repair the heater as I have no heat. A repair manual would be helpful.
  • 16 Answers
SOURCE: Bosch wta3510us tumbling NOT heating. Reset button?
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Posted on Feb 13, 2009
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
Posted on Apr 10, 2009
barkencoa
  • 3463 Answers
SOURCE: not heating
Probably the heater element has failed, it would probably be better to think of replacing the dryer at 10 years old, as Bosch spares are very expensive.
Hope this helps you to make a decision as to what to do.
Posted on Jan 04, 2010
Testimonial: "Thanks. Sounds like good advice."
  • 414 Answers
SOURCE: need help on Bosch nexxt 800 series dryer ....
Most Bosch appliance come with a minimum 2 year warranty from the manufacturer, before trying anything yourself please verify if it is still covered as you may invalidate your cover if you attempt a repair yourself..... that said if the limiter has been tripped there will be a reason... a. you are not letting the cycle finish, the last 10mins is a cooldown which the unit needs to do. b. the load going into the machine is far too wet, c. the outlet hose is kinked or blocked or d. you are running several loads straight one after another. I have put a link for the spare part placement on this post and I believe that the only resetable stat is item 405 on page four. this is accessed by removing the back panel (obviously isolate unit from mains before dismantling) and the limiter is on the side of the heater box at the bottom right, look at the unit from behind.
Hope this helps
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WTMC8321US%2f05&ESHOPTYPE=S
Posted on Aug 21, 2010
heatman101
  • 43501 Answers
SOURCE: Bosch axiss dryer WTA3510US wont run checked
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 21, 2010
Does this dryer have a reset? It is not heating
Hello, if you've never worked on a dryer, DON'T. The symptom you describe is probably an open heating coil or a blown thermal fuse mounted on the heater box. No, there is no reset of the type you are thinking of...If the dryer is running but not heating, usually the heater coil has a break somewhere along its length and must be replaced. This is an INVOLVED repair! Bosch products are different animals anyway and you must know how to disassemble, troubleshoot, and replace the faulty component(s). Next, after repairing the dryer, you must find the cause of the failure, most likely a kinked or blocked vent hose connected to the unit. Also, the airflow out of the dryer vent(outside your house) must be fairly close to what is coming out of the rear of the dryer with the vent hose disconnected. If it is significantly weaker, you very well might have a blockage in the wall in addition to a blockage in the vent hose.
Aug 13, 2015 | Bosch Dryers
When The door is open continues to run on my Bosch Axxis Clithes Dryer WTA3510US
the door switch contacts are welded together,normally it switches when the door is opened to light the interior drumm light and to the dryer circuit when the door is closed,but these contacts cant due to being stuck
Nov 15, 2012 | Bosch Axxis WTA 3510 Electric Dryer
Bosch wta3510us vented stackable dryer. I have reset the High Limit Thermostat and the unit is producing heat and air, although I'm not sure of the temperature of air flow. The unit came with the...
Go to www.repairclinic.com and enter wta3510us. You will be presented with a list of common replacement parts and may be able to view a generic Bosch video showing disassembly. This may help you figure out what's wrong and what has to be fixed.
Feb 28, 2017 | Bosch Axxis WTA 3510 Electric Dryer
Our tankless water heat will not heat the water-it won't ignite
Question posted under Boasch tankless. Model number not known.
Before calling service technician, open following link for Bosch troubleshooting resources, including phone and contact for Bosch, error codes, and possible manual, plus hours of reading and research:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
As you know from reading manual, tankless water heaters require yearly maintenance by trained service technician, or by homeowner. This action would check gas and pressure, venting draft, condensation drain, burner and combustion parts, igniter and-or pilot light, electrical connections, air intake and general condition of plumbing.
Problem you describe does not include error code.
Open following link for possible help with general plumbing problem:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with model number that appears on side of unit, and I can directly locate possible service bulletins and further troubleshoot resources available at Bosch for possible do-it-yourself diagnosis and repair.
Sep 02, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
heatman101
Sep 14, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Not heating
Jan 04, 2010 | Bosch Dryers
Apr 09, 2009 | Bosch Dryers
Jan 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
GE DPGT750 not heating
check your email this manual will take you step by step thru the repair
Jul 02, 2008 | GE Profile Harmony DPGT750EC Electric...
Washer dryer
Here is the link for a manual for your washer/dryer if you need it; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM sounds like the heating element has failed, or just possibly the thermostat for the hot air. follow this link for a list of spares if you want to try it yourself, or for bosch repair centre details if not. http://www.bshappliancecare.com/Bosch/boschspares.html ask if you want to do it yourself for any guidance you need. Hope this helps :)
Sep 29, 2006 | Bosch Logixx WFT 2806 Front Load...
Bosch Axxis WTA 3510 Electric Dryer Logo
126 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
