Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishes are not coming clean. I've tried reducing the size of the load, using all hot temps on every setting, etc.
  • Richard Johnson
    Richard Johnson Sep 01, 2012
    top spinner is not turning
  • Richard Johnson
    checked spinner all holes are clean
  • 4,323 Answers
Hi<br /> <br /> <br /> <font size="3" face="Calibri">If you are observing that the dishes are not clean, then you
Posted on Aug 21, 2010
  • Daniel Scott
    Daniel Scott Aug 21, 2010
    Hi
    If you are observing that the dishes are not clean, then you’ll need to follow certain steps to be sure where exactly the issue. First thing to check for is the detergent cup and spray arms. Check if the dishwasher’s spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps.
    Dishes are left unclean when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. The water inlet valve if faulty will draw very little or no water. However, if you observe that water pressure is fine and there is no issue with the Fill valve then check whether the dishwasher is draining. If it’s not draining then see if the drain hose is plugged or clogged. If drain hose is fine and the dishwasher is still not draining then there is some issue with the drain pump or drain filter. To check this you’ll need to disassemble the dishwasher and trace back the drain hose to a pump, remove the drain hose from pump and clean the debris from the pump and filter. Make sure you have lots of towels as there would be a lot of water coming out from the pump.
    Next thing to check if the dishwasher is draining and filling properly is water temperature. Water temperature should be between 120 and 140 F. If water is not hot enough then heating element has gone bad, to check the element you’ll need a multimeter. Use the multimeter and check if the Rx1 reading on the meter shows reading between 1200 (1.2K) ohms and 1500 (1.5K) ohms, if not the heating element has died.
    Please post back if more information is required.
My dishes are coming out with a white film on the glassware...also i can not get to my jet dry compartment
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 18, 2011 | Whirlpool Dishwashers
Tip
General Dishwasher cleaning
There are 3 types of energy used to clean the dishes a balance of all three are needed for the best results.
Chemical Energy - The detergent you use plays a big role in the cleaning ability. Phosphates do a great job but as new regulations come into play phosphates are being phased out. Detergent can get 'old' and loose it's cleaning ability. It has a short life span, so buy detergent in small quantities. If you have hard water you will need to use more detergent or even an additive like lemi shine or Glass Magic to assist with the chemical energy. Detergents for automatic dishwashers have a no sudsing agent to reduce foam and suds. Rinse aid plays an important role in eliminating spots and drying the dishes, yes drying. The rinse agent helps sheet the water off the dishware prior to the dry cycle, there is a product called Turbo Dry that can be used in place of rinse agent that works great for drying plastic. In summary use detergent like Cascade or Electrosol and a rinse aid
Thermal Energy - Hot water is important for both dissolving/activating detergent and breaking down food residue so it can come clean from the dishware. It will help to run the hot water faucet at the kitchen sink until hot before starting a cycle in the dishwasher. If cleaning is a problem use the Pots and pans or High Temp wash
Mechanical Energy - This is done by water pressure against the dishware, be sure to load properly, do not stack or shadow other dishware, be aware of where the spray arms on your dishwasher and make sure you do not block them when loading. If you have a filter in the unit, clean it often, if you do not you may still need to clean out the sump on occasion. The spray arms may get food or deposits in the small jets (holes) that the water needs to come out. Inspect and clean as needed.
Links to other dishwasher tips:
Poor cleaning on upper rack Whirlpool KitchenAid or Kenmore
Clean light blinking flashing 7 times
Calcium white powder build up hard water
on Apr 25, 2010 | Dishwashers
My dishes dull and and the glases have a fulm on them. Both dishes and glasses just don't have a "clean" feel to them. I've checked the arms for blockages and clogs, water temp is fine, and the...
Feb 08, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
The top rack on my kenmore ultra wash 3 dishwasher does not come clean and now even the bottom is starting to not clean
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Dec 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Purchased in 2003. Dishes were exquisitly clean till 2008. Our water heater temp was set at 140 temp. This heater was replaced with a heater now set at 125 temp. In the past two years dishes are nowhere as...
try turning on your water at the sink for a while on hot let it run then start the wash cycle that should help. what that will do is let the cold water run out of the pipes and therefore you will have a hot water start.
Dec 17, 2010 | Kenmore Dishwashers
Dishes come out with white chaulky film all over them.
Dec 17, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
When wash dishes, there is gritty like food on all the dishes and we use liquid for cleaning dishes. I rinse all dishes before I place in unit.....what is the problem?
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.The water temperature should be minimum of 140 degree Fahrenheit.
Also check the filter in your dishwasher for any debris accumulation.
Dec 09, 2010 | Maytag Dishwashers
Dishes do not clean
Nov 12, 2010 | Neff Dishwashers
They dishes are never clen
Nov 09, 2010 | LG Dishwashers
Dishwasher leaves soap residue on dishes
Nov 05, 2010 | GE 24 in. GLD5560LSS Stainless Steel...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
785 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
