Question about GE Ovens
Hi there. I have a JCBP35s stove/self-cleaning oven. When I turn the oven on "bake", the bottom element does not come on but the top element does (for some odd reason). The oven does not reach its specified temperature so I am assuming that the top element does not heat up that much. Can someone tell me what's wrong with my oven? Thanks
  • 1314 Answers
SOURCE: Oven is baking uneven
this is a common complaint on lower end ranges if you read the cooking instructions on the food it will say cooking times are approx you may have to adjust for your area that and your owners manual are your best bet on this promb adjusting the position of your racks help but forced like convection are the best way to go
Posted on Dec 30, 2007
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Posted on Sep 08, 2008
hbsurfdawg
  • 95 Answers
SOURCE: heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Posted on Mar 02, 2009
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
  • 189 Answers
SOURCE: Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Posted on Mar 23, 2010
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Self Cleaning Oven - Model RF360BXXW Serial # FA4005915 Turned oven on bake - bottom element is not heating however top element is. Tried to change setting to 'timed bake', 'broil' and 'clean'...
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Electric double stove
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Mar 26, 2007 | Kenmore 41389 Electric Double Oven
Ovens Logo
27 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
