Question about Panasonic SDR-H40 HDD Camcorder
How do I connect the camera to the ac adapter?
    Problem Solver:
  • 6 Answers
There will be a port with a cap (near the battery). You need to remove the cap and insert the adapter end.
Posted on Aug 21, 2010
Coolpix s3000 wont charge from car usb adapter?
The battery in this camera has to be removed and connect to an AC adapter to be charged.
  • Rechargeable Li-ion Battery EN-EL10
  • Charging AC Adapter EH-68P
May 15, 2012 | Nikon Coolpix S3000 Digital Camera
How do i know if my sl600 is charging? I have it pluggedin with the usb cable attached to the ac adapter. and the tiangular shape is orange. Does this mean its charging and how do i know when its complete
I'm glad to provide the information about charging the Camera. You can charge the Camera either using AC adapter or by connecting to the USB port on the Computer. Please make sure that you're not connecting AC adapter to the Camera when connecting to USB port on the computer. You can connect the Camera to the computer for more than 150 minutes(two and half hours) to fully charge the battery.
You can check the status of the LED on the AC Adapter while charging with the AC Adapter.
Thanks for understanding. Please let me know if you require any clarifications
Aug 21, 2011 | Samsung SL600 Digital Camera
Can I recharge V1073 Kodak digital camera by putting USB plug in computer or do I have to have an AC adapter to charge it?
This camera can be charge by connecting to a computer USB port so no need for you to use AC adapter to charge it, but its stll handy that you have a AC adapter just in case.
Apr 17, 2011 | Kodak EasyShare V1073 Digital Camera
Will my ac adapter chardge my camera? I have the Olympus c-50 (zoom)
No. You do have the battery charger, right? If not, get one
FYI
When connecting the AC adapter to the camera’s DC-IN jack, be careful not to
catch the plug on the jack’s cover.
● If the battery power runs out while the camera is connected to a computer,
image data may be corrupted. It is recommended that you use the optional AC
adapter when transferring images to a computer. Do not disconnect or connect
the AC adapter while the camera is communicating with the computer. Or just make sure your battery is fully charged!
● Power is consumed continuously during the conditions described below.
This could reduce the number of pictures that can be taken.
•When the monitor is turned on.
•Repeated auto-focus by pressing the shutter button halfway.
•Repeated power zoom adjustments.
•When communicating with a computer.
● Do not remove or load the battery and/or do not disconnect or connect the
AC adapter while the camera is turned on. Doing so could damage the camera’s settings or functions.
Dec 20, 2009 | Olympus Camedia C-50 Zoom Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Battery empty message when connecting olympus sw 1030 to laptop
Your recharged battery may be weak. May be time to replace.
If the battery power runs out while the camera is connected to a computer or printer, the image data may be lost or damaged. It is recommended that you
use the AC adapter. Do not connect or disconnect the AC adapter while the camera is connected to a computer or printer.Do not remove or load the batteries or connect or disconnect the AC adapter
while the camera is turned on. Doing so could affect the camera’s internal settings or functions.
Sep 02, 2009 | Olympus Stylus 850SW Digital Camera
Error E11 with DC4800 camera
This error "may" be associated with a battery problem. Is it possible that the battery is not charging properly.
Other things to try are as follows
1. Connect the camera to the AC adapter or insert onto the Camera Dock and press the Power button on the camera
2.
  • Remove all sources of power (batteries and AC Adapter) from the camera.
  • Remove the Kodak Picture Card or Compactflash Card.
  • Wait a few seconds.
  • Press the Power button twice.
  • Connect the appropriate Kodak AC Adapter to the camera.
NOTE: If you don't have the correct AC adapter, insert a set of fresh or fully charged batteries, according to the User's Guide.
3. The COMPACTFLASH Card could be corrupt. Reformat the card using a card reader or a PCMCIA card adapter in a notebook computer. ***Remember, reformatting erases all information from the card***
4. Try a different CF card as I have seen them fail causling errors.
Jul 01, 2008 | Kodak Cameras
AC adapter
The AC adapter recommended for use with the D-630 is the D-7AU (item# 200850). Use this adapter to conserve batteries when downloading to your computer, extended studio shoots, during printing, or while viewing images while connected to your TV or VCR. This can be purchased through authorized dealers or through the Olympus Emporium.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
AC adapter
The AC adapter recommended for use with the D-435 is the E-7AU (item# 200751). Use this adapter to conserve batteries when downloading to your computer, extended studio shoots, during printing, or while viewing images while connected to your TV or VCR. This can be purchased through our authorized dealers, or via the Olympus Emporium.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Panasonic SDR-H40  HDD Camcorder Logo
50 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
