Question about HP Deskjet D1341 InkJet Printer
Low ink message
I inserted new ink cartridges and still have low ink message. I have ran test pages, unplugged, reset, and yes i took off the plastic strip.
I have installed a new color cartridge and am still getting the low on ink message each time I try to print. Same propblem as sunshine 1597, just a different printer
  • 4 more comments
  • nsangar Sep 19, 2008
    I put a new ink cartridge and still get the low ink message. How do I fix this problem?
  • desertrobin3 Nov 06, 2008
    Help! I'm printing hundreds of documents and everytime I choose print the Interactive Services Dialog Detection Asks if it can show the message. The massage is that the "tri colored Cartiridge is low. Please have a new one ready." But I changed it days ago. Then it asks me if I want to go back to my desktop. uuugggh
  • DEETRATE Dec 02, 2008
    I have the same problem did you find any help
  • jon2dot Jan 18, 2009
    John825 I changed color cartridge but I still get message that ink is low
  • Anonymous Apr 08, 2009
    same problem any resonable help or why it happens: ie software problem.
  • Anonymous May 11, 2009
    Whenver i try and print anything i get Interactive Services Dialog Detection Asks if it can show the message. The message is that the "tri colored Cartiridge is low". Then sometimes it will log off
Just ignore the message and print
if it doesn't print try to dip the lower part of cartridge in warm water, not hot, for five mins and dry it with tissue and try to print
Posted on Mar 06, 2009
What do I need to do when I install new ink cartridges to get the printer to stop showing that the ink is low or out ?
You will need to reset the software in most cases as the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jul 21, 2011 | Canon PIXMA MP470 All-in-One Printer
HP Printer Reset
Resetting the printer can resolve several issues that may emerge. All the steps in the two sections below must be followed completely and in order for these resets to work. Performing a soft reset A soft reset, also known as an Electrical reset, can be used to restore the printer to a ready condition when a cartridge, paper, or other printing issues occur. This reset method should be used for the HP Photosmart 100, 130, 145, 230 and 245 printers. Perform a hard reset for all other HP Photosmart printer models.
  1. Disconnect any USB cables attached to the printer and remove any memory cards from drive bay.
  2. Restart the computer.
  3. Unlock the ink cartridge locking clips.
  4. Remove all ink cartridges.
  5. Lock down the ink cartridge locking clips.
  6. Close the main printer door
  7. Turn the printer off with the Power button and wait for the printer to shut down before proceeding to step 8.
  8. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  9. Wait approximately fifteen to forty-five seconds to allow all current to dissipate from printer.
  10. Re-plug only the AC adapter into the wall outlet then into the printer, but do not plug in the USB cable.
  11. Wait for the appropriate missing ink cartridge error to verify that printer can recognize this error.
  12. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  13. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  14. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  15. Test for printer functionality.
Performing a hard reset A hard, or mechanical, reset is performed when the printer is in a condition where its normal printing process is interrupted. Examples include a paper jam, carriage stall, or mechanical noise. To perform a mechanical hard reset, follow the steps below.
  3. Remove any paper from the paper tray.
  4. Unlock the ink cartridge locking clips.
  5. Remove all printer ink cartridges.
  6. Lock down the ink cartridge locking clips.
  7. Close the main printer door.
  8. Turn off the printer using the power button and wait for the printer to shut down before proceeding to step 9.
  9. Unplug the power from the back of the printer.
  10. Unplug the power adapter from the wall outlet.
  11. Remove the rear access door.
    NOTE: The clutch is located in the same place as pictured above in Figure 1, however, you must access it from the left, just above the paper output tray.
  13. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  14. Release the clutch and roll the wheels up two more rotations.
  15. Locate and then roll the internal rollers in an upward direction until a clicking sound is heard.
  16. Reinstall and lock the rear access door.
  17. Connect the power adapter to a wall outlet.
  18. Reconnect the power cable to the printer.
  19. Turn the printer on.
  20. Re-insert the paper into the input tray.
  21. Wait for the appropriate missing cartridge error to verify that the printer recognizes this error.
  22. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  23. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  24. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  25. Test for printer functionality.
Goodluck,
And please don't forget to rate me as fixya..
Feb 02, 2008 | Office Equipment & Supplies
I have replaced the color cartridge and now the printer does not recognize color. Can you please help me on this?
Hello
Turn on the printer and check the LCD screen for messages. If your printer isn't recognizing what you know to be a new cartridge, the "Low Ink" warning will still be on the screen. Press the green "OK" button for now--if you want the message to reset later, just open and close the lid.
Try printing a test page. Sometimes the ink cartridge simply has a faulty chip and the printer cannot recognize the ink levels.
Open the lid via the handle under the copying tray and remove the ink cartridge in question. Check the bottom for the plastic tab. This tab must be removed or the printer cannot recognize the cartridge. Sometimes when the tab is pulled off, a small strip remains, and this can interfere with printing. Hold it in good lighting and use your fingernails or a knife to gently pry off any remaining bits of the plastic tab. Replace the cartridge, close the lid, and print a test page.
Call the store or website customer service where you bought the ink if the above steps do not work Tell them what you tried, the exact error message your printer is giving you, and when you bought the ink. If it's within 30 days of purchase, they probably have a return or exchange program.
Oct 04, 2010 | Lexmark Office Equipment & Supplies
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Mp 145 errors E 5
ud semua cara sy coba g mau juga mas, tlng bantuanya mas.
Apr 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Epson R260. Brand new. Green light blinks, red stays on.
https://www.manualslib.com/manual/357821/Epson-Stylus-Photo-R260.html?page=55#manual says Epson's manual thinks Red
paper out light ) is on and green P power light flashes means
If you're printing on paper, your paper ran out or multiple
pages have fed at once. Make sure you push the tray lever
up to set the front tray to the paper (lower) position. Then,
load more paper and press the ) paper button to resume printing.
If you're printing on a CD or DVD, the CD/DVD tray is not
inserted. Follow the instructions beginning on page 27 to
insert the tray, then press the ) paper button.
Nov 06, 2017 | Epson Stylus Photo R260 InkJet Printer
Lexmark X125
This is very unusal with All-in-one printers. Have you try Hard reset till? Keeping the power on button press for 10 sec till it get on..
Also is the error showing on display screen of printer or at PC? Which Os is running on your PC.
Please also try this --> Power off the printer then computer, Unplug the printer from PC and then main power board--> then restart PC --> after then shut down PC and then again attach printer to PC and power on.
Let me know about the printer spooling if showing any error in Printer setting window.
Nov 02, 2008 | Lexmark X125 All-In-One InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Lexmark x4720 ink cartridge installation
Stop buying lexMark products, They are not worth the plastic they are made from.
Jan 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
HP Deskjet D1341 InkJet Printer Logo
313 people viewed this question
Ben Johnson
