Question about Bissell Vacuums
How do I replace the battery in my bissell 2880 floor sweeper?
Bissell cordless sweeper rear wheel is not moving, its stuck
Hi Anju. Hair or string can cause the wheel not to turn. After removing any hair or string and the wheel still doesn't turn you may want to contact us.
Here's a quick link to reach us: http://www.bissell.com/contact-us/?cid=ccsocial
Aug 04, 2013 | Bissell perfect sweep turbo 2880
Beaters bar will not turn
Hi Earl! It can't be easy to pick up debris when the brushes don't turn. If you've owned the sweeper for some time, it may be necessary to replace the brushes.
Here's a quick link to ordering from our website: http://www.bissell.com/search.aspx?g=1&s=2600&cid=ccsocial
May 12, 2013 | Bissell 2600 Sweeper Vacuum
Bissell sweeper 6594 switch wont stay down to run
You may want to contact one of our service centers for assistance. Here's a link to assist you in locating one.
http://www.bissell.com/service-centers/?cid=ccsocial
Sep 30, 2012 | Bissell 6594 PowerForce Bagless Upright...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
The brush on my bissell prolite multicyclonic vacuum won't turn. It seems like it is jammed, but I checked for anything that might be stuck in it and don't see anything. Is there a reset button?
I had the same problem with my old Bissell sweeper ( I bought a new rotating brush each time this happened then I bought a new sweeper the next time it happened -last Dec. 2009.) Unfortumately I bought a new Bissell and now it is happening again to the new sweeper. I do clean the brush often but what has happened is that the hair somehow gets inside the brush via the end caps???This sweeper does have end caps that can be removed for cleaning --although not that easily when they are locked up. I did this yesterday but before I could remove the end cap I had to use a pin, scissors, etc. anything that I could get into the groove to remove lint, etc. that caused it to lock up. Then when I got the end cap to move a little, I pried it off. I found hair, etc. inside where the metal rod is which I don't think should be happening --I used a seam ripper also to try to get some out. I have owned many different brands of sweepers and have never seen this problem before. Then, I put the end cap back on, however, it was not smooth on the inside--almost like it had melted when it locked up. So, the sweeper brush now moves but it is noisy. I guess I will buy another brush -- but this seems ridiculous for a new sweeper--the customer service rep told me that the brush does wear out.... but not on a sweeper that is less than a year old. There is no wear and tear on the brushes. Oh, and the CSR told me that they haven't had people call about this problem --I am guessing they are just buying new brushes or new sweepers. The sweeper def. has great suction but I think other brands do also..
Nov 11, 2010 | Bissell 17G5 PROlite MultiCyclonic Bagless...
The sweeper doesn't have proper suction
Make sure all filters are clean and then check for obstructions begining at the nozzle (floor head) and follow the chamber all the way to the dust bin. Most bagless models have a dense foam filter just under the top.
Oct 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless vacuum,when turned on dust flies out sweeper
Dust flying out of the sweeper indicates that their is a blockage in the pathway that the dirt normally travels to get into the dirt collection chamber. Turn the sweeper upside down and look for a blockage of some kind. Also, empty out the canister and look to see that the pathway into the canister is clear.
May 18, 2009 | Vacuums
Roller brush doesn't turn
Sounds like the belt is maybe slipping did it brake the new belt as well?
Mar 10, 2009 | Vacuums
Vacuums Logo
50 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
