Question about La Marzocco Linea Group 1 Espresso Machine
Expansion valve won't regulate pressure. how do I remove/clean/adjust this valve?
    President:
  • 1,618 Answers
The only thing the expansion valve does is open when the pressure gets to 12 bars when the coffee boiler is heating or when you are backwashing the groups. If you need to adjust wait until red light comes on to say coffee boiler is heating then if gauge is going beyond 12 bars turn end of expansion valve to left to keep it at 12 or right to take it to 12 if it is lower, before doing this make sure pump is set to 9 bars.
Posted on Sep 23, 2010
2001 Nissan Pathfinder, expansion valve malfunction. How to remove evaporator/expansion valve
Evacuate all refrigerant and recycle. Disconnect the high pressure line from the EXP valve and disconnect valve. Clean surfaces and install new O rings. Reassemble. Pull a vacuum on the system and recharge with refrigerant and oil. This is NOT a DIY job.
Aug 02, 2017 | Nissan Cars & Trucks
What regulator does a empire model 115 15000 btu take?
The regulator on the heater probably is not but is probably a device to prevent the heater being used unless the gas pressure is high enough and also serves to prevent air entering the gas line and also serves to arrest flashbacks.
The standard propane low pressure regulator is 14" water gauge but the heater might need a high pressure regulator. The best way to decide which type of high pressure regulator to use, because there are several, is to use an adjustable regulator.
After installing the adjustable regulator the pressure is increased until gas can be heard to be flowing and the heater lit. The regulator should then be adjusted to produce a clean flame of the correct length and then the regulator adjustment locknut should be tightened.
If the heater is to be used indoors it is important to ensure there is plenty of ventilation and the emissions are checked by a gas engineer.
Sep 06, 2017 | Empire Heating & Cooling
Where is the orifice tube located on 88 buick park avenue
Inspect/Test/Replace To raise pressure, there must be a restriction in the air conditioning system. The restriction divides the system into the high side and the low side. The terms high side and low side refer to the high pressure and low pressure within the system.
The flow control can be either an orifice tube or a metering device called an expansion valve. A thermostatic expansion valve controls the amount of refrigerant that is allowed to flow to the evaporator. A temperature sensing bulb on the evaporator inlet controls the expansion valve.
  • A bad expansion valve will cause low readings on both the low and high side.
  • Failure of the sensing bulb is the most common problem.
  • Sometimes the valve can become plugged with debris.
  • If the sensing capillary tube is warm, there is high pressure that pushes on the diaphragm.
  • The sensing bulb checks the temperature of the outlet line of the evaporator.
  • If it is warm, it opens the valve.
  • Pressure on top of the diaphragm tries to push the valve open.
  • The operation of the expansion valve can be checked.
  • Some expansion valves can be cleaned, repaired or adjusted.
f73-15a.gif This system uses an expansion valve as it's flow control device. Some expansion valves are wrapped with insulation. When the sensing bulb is in the evaporator case, it does not need to be wrapped because it stays cold. When an expansion valve is packed in that type of system, it is only to silence the noise that the evaporator makes.
CAUTION
Only EPA-certified technicians can purchase R-12 refrigerant, since proper recovery and recycling techniques are required to prevent damaging the environment. Improper disposal of R-12 refrigerant can result in a fine.
Jun 06, 2012 | Buick Park Avenue Cars & Trucks
No regulated pressure
Pressure regulator can fail giving little or no pressure at quick connect. There is a plunger inside of reg that can get stuck due to moisture/rust and /or threads of adjustment knob could strip. Back side of regulator (opposite the knob) find a hex nut. Remove nut (let out all the air from tank before removing nut) and pull plunger/spring away, clean , lube and reinstall for test. If still no joy, remove knob by moving stop pin up (tiny pin close to lip of knob and or spring clip) and turning counter clock wise. Remove the piston from cylinder of reg making note of how it was installed, lube and reinstall, make sure that the threads inside the knob are good. Replace knob and turn in to max pressure. If still no joy, replace reg or install temp air outlet. To install temp outlet, remove safety pop valve (remove all air from tank) and install tee fitting. Reinstall pop valve to one port of the tee fitting and quick connect to the other (or generic regulator ((sold at Lowes)) between quick connect). Good luck
Nov 11, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Water pressure decreases as the water runs
Probably a clog in galvanized pipe.
Expansion tank is not whole-house pressure regulating tank. It is localized protection for plumbing exposed to high pressure caused by very hot water.
If you house has pressure regulating valve, then that can be a cause.
For low water pressure in household, the following link might help:
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 07, 2011 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
My Nuova Simonelli espresso machine has a water line to it and a waste line that goes to a bucket. Dumping the bucket is no problem, but the problem is that the bucket has started filling up when we aren't...
Probably is the group valve dripping, Remove the drip tray and look under the front cover.
You will see a drip. If that's the case the valve needs to be replaced.
Jan 19, 2011 | Nuova Simonelli Mac 2000 I Group Espresso...
Outlet pressure?
have you tried turning the pressure adjustment knob clockwise to increase regulated, not tank, pressure
Dec 12, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
99 Toyota Tacoma a/c reads high pressure on low pressure side
Does the compressor run?
Low side could be high without a running compressor.
A running compressor?
The expansion valve itself is about $50 and bolts in.
You will have to remove the 134a gas before installing a replacement expansion valve and vacuum the system before recharging.
Sep 07, 2009 | 1999 Toyota Tacoma PreRunner
Low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
May 24, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
La Marzocco Linea Group 1 Espresso Machine Logo
312 people viewed this question
Top La Marzocco Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Goldsmith
Jim Goldsmith
steve morris
steve morris
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
