I would change all the fluids and either try dry gas or i would recommend that the gas tank be thoroughly drained and new gas put in the tank.If you have a hard time getting started try to use starter fluid in carburetor or if you have none just use gas. If the vehicle is equipped with fuel injectors locate air filter and follow air duct to engine that is where starter fluid or gasoline will have to be pored to prime the injectors.if it don't start the engine should be tuned up with a major tune up replace all filters ect even if it starts without tune up i would tune it up asap!
I bought an 87 eco van. it sat up a year without being cranked. it ran fine but it died with gas in it. it kinda acted it ran out of gas once and then died. it will turn over but won't crank.
