Question about Lexmark P3150 All-In-One InkJet Printer
The cable that hooks the printer to the computer is called what type of cable and where can they be purchased and any idea how much they cost?
    President:
  • 2,571 Answers
It is a USB cable type a to b.
They are quite cheap £5 or less. check here (amazon)
http://www.amazon.co.uk/Belkin-Gold-Hi-Speed-Device-Cable/dp/B00004Z5T2
Posted on Aug 21, 2010
Testimonial: "very quick response and helpful"
Brother MFC 820CW
These sort of parts are very hard to source as generally the repair cost is more than the cost of a new printer. I have had success doing these type of repairs by buying a length of ribbon cable from an electronic parts supplier and carefully soldering the wires onto the circuit boards. It is delicate work and you need to be careful, but it can be done if you take your time.
Jun 21, 2017 | Brother MFC-820cw All-In-One InkJet...
Lemark x5650
You will need a USB cable to connect the printer to your computer. The USB has Type A on one end and Type B on the other. You can purchase this from any electronic shops around your area or you can also call Lexmark Technical Support to request for one. Lexmark printers that are capable of wireless connection have a Wifi light (usually found on the upper right corner on its front face). But before you're able to connect wireless successfully, you will still need to connect the printer to your computer temporarily with the usb cable for configuration. Hope this helps.
Jun 10, 2010 | Lexmark X5150 All-In-One InkJet Printer
Just purchased esp printer, does this have to be
You do not need to connect it to computer to print photos. the printer, place any document on the scanner glass and put papers in the document tray and press copy. if the printer does not work, Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.The usb cable does not comes with the printer and you need to purchase it additionally
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Power cable missing
Most printers require that you purchase a printer cable. It has a USB on one end and the other end looks square. If you want one that plugs into your USB port it is called a USB 2.0 A - B Scanner Printer Cable. They come in different length. The longer they are the more they will cost. You can get them off of Ebay by searching Printer cable. If you will be plugging the printer into a parallel port make sure you get a printer for that kind of port. You can usually purchase printer cables at any store that sells printers or computer parts. They are a pretty common item. Hope this helps.moz-screenshot.jpg
Jul 28, 2009 | Dell Office Equipment & Supplies
How to hook up 6210 printer to compac presario computer?
Your printer has a USB aside from the PicbridgeHP PCL3 connection so you should be able to install it in any computer with a working USB port.
Nov 05, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Don't know how to setup printer or hook to computer
Hello calbj5, Since you didn't provide a make /model computer or printer..all I can provide is general guidelines for you.. Your printer will have a few features in that you will need to determine what fits your system best.. Many newer printers use a USB port to communicate with the computer.. This is a modular type plug ( one end will match the plug on your printer ) and the other end will be plugge dinto any available USB port on the back of your computer, ( older systems used what they call a D-Type cable assembly ) and if tha is what you require, you willl need to get that cable. Like I said.. most newer style printers come with the USB type cable as standard. You will also find the power cord provided with your printer..One ened plugs into the back or side mating plug of the printer and the other to your power receptacle ( hopefully you are using a surge protector set up)
Once you have both cables hooked up and plugged in.. you've probably been provided with a CD that came with your computer as well as instructions for loading the drivers on that CD ( most of the time) you just insert the CD into your CD player and it wil ask a few questions and self load.. Please let me know if this gets you going or youneed clarification.. It's always a good idea to provide brand and model numbers in your questions.. That helps us in helping you.. Good Luck !
Sep 23, 2008 | Computers & Internet
How to connect printer to computer
the cables that your printer uses us called USB and another one is ethernet. any local store has this so you can go to radioshack, walmart, bestbuy and you will be able to get these types of connectors for your printer.
Jul 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
RCA Entertainment Series PiP CRT, black screen, static/squeel sound
Hello krysis2000,
Sounds that this might be the proverbial problem some brands have, specially RCA (funny this problem still exists. It was around even when I was a resident engineer for RCA Corp. 20 years ago and hasn't been modified). This problem relates to the tuner assembly. It is a relatively easy fix for a skilled technical person. The cost of repairing it shouldn't even be close to its replacement value, so, in my opinion, worth fixing. Since I do not know the model or age of your TV set (or the inclination you might have to take this as an excuse to get a new HDTV set - LOL), it is entirely your call!!
Hope this helps. Let me know.
cancerags
Dec 29, 2007 | Televison & Video
Lexmark P3150 All-In-One InkJet Printer Logo
136 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
