Question about Thermador SEC302 Electric Double Oven
Thermador SEC302BP Showed an F33 error code and now upper oven does not reach temperature. Stay 50-100 degrees below set temp in all modes. Lower oven tested OK temp once.
3 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: I have a thermador double
Hi awadsworth,
The "F33" fault code description is a faulty temperature sensor also indicates as an "upper oven over temperature while cooking". The easiest way to correct this error is by checking the sensor harness and harness connection between oven sensor and oven control. If wiring is ok you need to replace the oven temperature sensor. Your options are limited unfortunately. It is something that a technician will need to replace for you. You may have a technician come in and check it over.
The original Thermador part number is 35-00-306 and available at on-line supplier "repairclinic.com" for approx $125USD. You may also double check the specific model number of your machine, it is located behind the grill by the door latch.
Hope it helps.
Thank you for using FixYa.
Posted on May 06, 2011
ginko
  • 19396 Answers
SOURCE: Thermador Built in oven scd302 not heating upper
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
Posted on May 31, 2011
Flashing F33 error code thermador double oven
either a bad oven sensor or a bad power relay board.
Feb 10, 2014 | Thermador SC272T Electric Double Oven
Thermador c272u double oven error code f33
over temperature. Check the oven sensor, if ok, replace the relay board for that oven (upper or lower)
Sep 16, 2012 | Thermador Ovens
I selected "proof" and turned the oven on this
F33 ( upper oven over temperature while cooking ) Check sensor should read 1080 ohms at room temp.
You will need to replace the oven temperature sensor. There is no quick fix for this problem to get you up and running on this Thanksgiving day, sorry. Where are you located and I will see what resources are close to you so you can make the repair?
Nov 24, 2011 | Thermador C301U Electric Single Oven
We have an electrolux E30EW85GPSS double oven. The lower oven appears to work properly. However, the upper oven will bring itself up to the set temperature but after reaching it, does not stay on and...
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control board however, as the issue is only with upper oven it is most likely that the temperature sensor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jun 17, 2011 | Electrolux E30EW85GSS Oven
F33 CODE
this is uper oven over temperature while cooking , check sensor should read 1080 ohms, at room temp, if ok replace power relay board
Apr 20, 2011 | Thermador C301U Electric Single Oven
When using the BAKE setting, the desired temperature is input and the oven begins a preheating phase. The temp will only rise to one degree less than the desired setting, and the oven never reaches the...
more than likely there is an issue with one of the temp sensors. you will need to press and hold clear then upper on off at the same time then release them then immed. press clear 3 times and hold on the 3rd till the service screen appears. on the right side you will see internal temp and catalyst temp they should be equal or very close. ill bet one of them is alot higher than the other if so the sensor will need replace but depends which one is bad as there are 2 of them. if the problem is on the lower just repeat above but use lower instead of upper
Dec 07, 2010 | Miele H398BP2 / H398B2 Electric Double...
I have thermador double oven (I think it is model sec30 something-cannot read it) which i have had for 3 years with consistant problems with F33 displaying. Can you help me in telling me how I can reset...
In 30+ years of servicing I have replaced very few oven sensors due to failure. True, a sensor may need to be replaced, but there is also another possibility and a much cheaper solution at that.
If you look at the two soldered pins where the sensor wires attach at the oven relay board, you may find them to have heat fractures in the solder around one or both. These are very hard to see with the untrained eye, but any small fracturing will change the sensor reading to the main board. Therefore it is important to re-solder these pins at the relay board.
This is a job for a qualified service Tech and should not be attempted by the average DIYer.
Dec 04, 2010 | Thermador SMW272 Electric Double Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven Doesn't Reach Set Temperature
Check the element for burns/wholes this was problem for our.  Easy fix and part is about 35 to 40 dollars.
Nov 16, 2006 | Thermador SC272T Electric Double Oven
Thermador SEC302 Electric Double Oven Logo
254 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
