Question about The Home Marketplace 70047 Waffle Maker
My vitantonio waffle maker wont open, is there an automatic lock until the waffles are done? or what?
Once the waffle is cooked how do you open the iron?
You need to spray oil on the waffle iron top and bottom before you put the batter in so it doesn't stick.
When it's cooked (steam mostly stops coming out), just lift the top off, and use a fork to lift your waffle out.
Aug 27, 2015 | Kitchen Appliances - Others
Vitantonio waffle maker
have you open your waffle? if you already open it, check if theres a cut to the wires of you your waffle or check if there is a lost tread on something. thanks!
May 05, 2008 | The Home Marketplace 70047 Waffle Maker
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
How do you know when it is done cooking?
Usually there is steam rising from the waffle maker when cooking, if there is no light on it to tell you when it is done watch the seam and as it is getting done there will be less steam than when it first started, if there is a light watch when it goes off or when the steam stops and then count minutes to when you open it to see how browned toasted you prefer
May 17, 2009 | Krups 65475 WaffleChef Waffle Maker
I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
Mar 24, 2009 | Kitchen Appliances - Others
Waffle Iron Sticking...HELP
Try using 2 Tablespoons of oil in your recipe.
Mar 21, 2009 | Kitchen Appliances - Others
Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Aug 17, 2007 | Salton WM8BEL Belgian Waffle Maker
Kitchen Appliances - Others Logo
42 people viewed this question
Top The Home Marketplace Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a The Home Marketplace Kitchen Appliances - Other Expert? Answer questions, earn points and help others
