Question about Frigidaire Dryers
The dryer (Frigidaire Euro design BCEQ2152ES) is off and then suddently it turns on (by itself) the selecter of "dryeness" level change alone. After a while E68 appears and it bip. We saw that E68 was the error code for a button jam so we try to press all the push button to unjam it but it doesn't work... We also unpluged it (to stop the noise) for a while and plug it back again and the problem is still the same.
SOURCE: Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Posted on Jan 03, 2008
SOURCE: My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Posted on Mar 30, 2009
  • 64 Answers
SOURCE: E68 But big whooping deal. I don't want to call a
Try to vacuum it out or use a small brush. Run water on screen sometimes they look clean and are not.
Posted on Jun 10, 2009
  • 278 Answers
SOURCE: press start button and dryer will start and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Posted on Dec 10, 2009
jyackle5
  • 8197 Answers
SOURCE: E68 error message
The code is for a stuck button on control panel. You will need to replace the control panel
Posted on May 16, 2010
My Frigidaire gas dryer will turn on for one minute and then the lights start blinking and it turns itself off. it Seems to be heating fine it just won't stay running ???
I know with some models, if the lint hose is plugged somehow, that will cause the dryer to turn itself off to prevent overheating.
See if a squirrel or something stuffed it up. At least you can then rule that out.
Sep 29, 2015 | Frigidaire Dryers
Tip
How to Unlock Any Appliance or Turn Off Child Lock
<span style="font-weight: bold;">Bosch Dishwasher:</span><br /> <ol> <li>To deactivate, press and hold the "&lt;" button until the Child Lock LED goes out.</li></ol><span style="font-weight: bold;">Bosch Microwave:</span><br /> <ol> <li>Press "Settings" followed by the number "5" to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Bosch Washing Machine:</span><br /> <ol> <li>To deactivate Child Lock, press the Start/Pause button and hold down for 5 seconds.</li></ol>or<br /> <ol> <li>Press the Menu button until CHILD LOCK :ON appears in the display.</li> <li>Press the Select button until CHILD LOCK :OFF appears in the display.</li> <li>Press the Start/Pause button and the key symbol should disappear.<br /></li></ol><span style="font-weight: bold;">Danfoss Thermostat:</span><br /><br /> <ol> <li>Press the control knob or button and hold it in place.</li> <li>Turn the knob counterclockwise until you see the word "Code" appear in the display.</li> <li>Turn the knob clockwise and select the code "0033."</li> <li>Press on the control knob until you see an icon of a clock or a hand appear or disappear indicating that the child lock has been set or unset.</li></ol><span style="font-weight: bold;">Delonghi Microwave:</span><br /> <ol> <li>To deactivate Child Lock, press the STOP/CLEAR key until the beep is heard.</li></ol><span style="font-weight: bold;">Delonghi Portable Air Conditioner:</span><br /> <ol> <li>Pressing the "+" and "-" buttons on the control panel together for more than two seconds unlocks the keypad.</li></ol><span style="font-weight: bold;">Fisher & Paykel Dish Drawer:</span><br /> <ol> <li>Disable the child lock by pressing and holding the key with a key and lock symbol printed on it until the padlock symbol disappears from the screen.</li></ol><span style="font-weight: bold;">Frigidaire Dishwasher:</span><br /> <ol> <li>Press and hold the No Head Dry button (or the Rinse Only, Delay Start or Air Dry button depending on model) for 3 seconds.</li></ol><span style="font-weight: bold;">Frigidaire Dryer:</span><br /> <ol> <li>Press and hold the "Control Lock" button for five seconds to release the lock.</li></ol>or<br /> <ol> <li>Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.</li></ol><span style="font-weight: bold;">GE Dishwasher:</span><br /> <ol> <li>Press and hold the Heated Dry button for 3 secs.</li></ol><span style="font-weight: bold;">GE Electric Stove:</span><br /> <ol> <li>Press and hold "Lock" for three seconds to release the child lock function.</li></ol><span style="font-weight: bold;">Kenmore Dishwashers:</span><br /> <ol> <li>Press the "Heated Dry" button, and hold for four seconds until the "Lock On" icon light turns off.</li></ol>or<br /> <ol> <li>Hold the "Sensor Dry" or "Lock" symbol down for three seconds until the lock indicator light goes off.</li></ol><span style="font-weight: bold;">Kenmore Dryer:</span><br /> <ol> <li>Press and hold the AUTO DRY LEVEL button for 3 seconds.</li></ol><span style="font-weight: bold;">Kenmore Microwave:</span><br /> <ol> <li>Touch and hold Cancel for 5 seconds to deactivate the lock.</li></ol><span style="font-weight: bold;">Kenmore Range:</span><br /> <ol> <li>Push and hold the Lock button for 10 seconds.</li></ol><span style="font-weight: bold;">Kenmore Washing Machine:</span><br /> <ol> <li>Press and hold "Drain & Spin" for 3 seconds to release the child lock.</li></ol>or<br /> <ol> <li>Press and hold Cancel for 10 seconds.</li></ol>or<br /> <ol> <li>Hold the "End of Cycle" button down for 5 to 6 seconds.</li></ol>or<br /> <ol> <li>Hold the Child Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Dishwasher:</span><br /> <ol> <li>Press and hold Energy Saver/Dry button for 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Microwave:</span><br /> <ol> <li>Press and hold the "Cancel" or "Start" button for five seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Oven:</span><br /> <ol> <li>Touch and hold START for 5 seconds.</li></ol><span style="font-weight: bold;">LG Dishwasher:</span><br /> <ol> <li>Press and hold the Spray and Rinse button simultaneously for 3 seconds.</li></ol><span style="font-weight: bold;">LG Dryer:</span><br /> <ol> <li>In models that include a rack dry, usually holding the [rack dry] button for three seconds will disable the function.</li></ol><span style="font-weight: bold;">LG Refrigerator:</span><br /> <ol> <li>Press and hold the Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">LG TV:</span><br /> <ol> <li>Open the menu, select lock (padlock symbol) then select lock system, then select off.</li> <li>Press exit to exit the menu.<br /></li></ol><span style="font-weight: bold;">LG Washing Machine:</span><br /> <ol> <li>Press and hold "Dry" & "Spin" buttons together for a few seconds. </li></ol>or<br /> <ol> <li>Press and hold "options & select" until the light goes off.</li></ol>or<br /> <ol> <li>Press and hold "end of cycle" for over 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold the PRE-WASH/Child Lock buttons for 3 seconds. </li></ol><span style="font-weight: bold;">Maytag Dishwasher:</span><br /> <ol> <li>Press the Heated Dry button for three seconds.</li></ol><span style="font-weight: bold;">Maytag Microwave:</span><br /> <ol> <li>Press and hold the "Enter/Start" button for 3 seconds</li></ol><span style="font-weight: bold;">Panasonic Microwave:</span><br /> <ol> <li>Press "Stop/Cancel" 3 times to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Philips TV:</span><br /> <ol> <li>Using your TV Remote, press the 'MENU' button, select FEATURES and press cursor right.</li> <li>Press cursor up/down to select CHILD LOCK and press cursor right.</li> <li>The screen will prompt you for PASSWORD, key in you password if known. If the password is unknown, then key in the code 0711 twice.</li> <li>Press cursor up/down to select CHILD LOCK, press cursor right to change the status to OFF.<br /></li></ol><span style="font-weight: bold;">Samsung Dishwasher:</span><br /> <ol> <li>Hold down the Delicate and Rinse buttons simultaneously for three 3 seconds.<br /></li></ol><span style="font-weight: bold;">Samsung Refrigerator:</span><br /> <ol> <li>Press and hold the Ice Off/Lock button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Ice Off button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Lighting button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Child Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Dishwasher:</span><br /> <ol> <li>Press and hold Heated Dry button for 4 secs.</li></ol><span style="font-weight: bold;">Whirlpool Dryer:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Washing Machine:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol>
on Jun 17, 2011 | Washing Machines
How to reset control board on Frigidaire affinity gas dryer
Hi Friend, thank you for your inquiry!
I understand your Frigidaire dryer is experiencing a shutoff issue. It is possible that you may either have a communication error from the main control board or the timer itself may not be operating correctly. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Best regards! - Z
Jun 03, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
"LOC". As I turn the dial to the requested setting, all the times (15min. 55 min., etc.) are displayed, but as I go to push the &#39;start&#39; button, the screen says, "LOC",...
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Electric Dryer
Frigidaire dryer caqe7001lwo code pau
The unit has paused itself. Check for any other error codes or for any clogs in the dryer lint trap, the duct venting system to the outside and make sure the unit is level.
Jul 22, 2012 | Frigidaire GLEQ942CS Electric Dryer
We have a Frigidaire gas dryer about 2 yrs old. I placed a load of towels to dry (at "Towel" setting) everything went fine. I placed the next load and chose "Normal" setting. The...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2011 | Frigidaire Dryers
Dryer code says "loc" and
Jul 20, 2011 | Frigidaire Electric Dryer
My dryer suddently stopped working
heatman101
Jul 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer seems to take a long time to dry. I read
general rule of thumb for dryer taking too long to dry is indeed an issue with the venting, (too long, clogged, partially clogged) or perhaps even the opening in which it leaves the home has become blocked in some way, i reccomned cheking your venting before calling for service. as far as dryer sheets the would hamper the ability to sense the dryeness from inside the dryer, not the vent itself( leaving fabric softener on the metallic sensor bars within the unit itself
Jan 27, 2010 | Fisher and Paykel Dryers
Frigidaire GLEQ2152ESO Dryer flashing AD
AD means "auto dry", which means the dryer is supposed to be detecting the moisture levels in your clothing and adjusting the drying time accordingly.
If your dryer is flashing "AD" and turning off shortly after the start, there is likely a problem with the mechanism designed to detecting the moisture levels. If it turns off after trying to use all various settings (including the no-heat feature), it is likely a wiring issue.
Mar 27, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
532 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
