Question about Daewoo Televison & Video
The picture of my tv is doubled up and continues to to go in an up and down motion
  • augustineiwe Aug 22, 2010
    The model # is DSJ 5510CRA
    The serial # is GT52HT0056
    Answer to question 1. Yes it happens only on tv programs
  • augustineiwe Aug 23, 2010
    Whom do you recommend in the Kansas city area that can fix this problem. My zip code is 64155
    President:
  • 1,961 Answers
That is a problem on the jungle IC/chroma this the main processor ic of your tv..before replacing the ic check and replace first the bulging capacitors from the vertical section the value of the capacitors are usually 2.2uf/50v,1uf/50v and other small values..after replacing and nothing happens then replace the jungle ic...thanks and goodluck!pls rate my help
Posted on Aug 23, 2010
  • Daewoo Master
  • 11,800 Answers
The vertical deflection module is faulty. What exactly is the fault can be determined only after testing. Luckily this is a simple fault that will be cheap to fix by a pro.
Posted on Aug 22, 2010
  • Azrael SRL Aug 23, 2010
    Sorry, i don't live in the Midwest and i don't know anyone around there. But any decent repairman should be able to fix it easily. Ask neighbours for  one of them.
  • Daewoo Master
  • 5,807 Answers
Before i present my possible solution to your problem, i would
like to know , the Model of your Daewoo TV. ( year perhaps )
Does it happen on all inputs ?,
like Video Input or TV programs ( built in tuner ) ?
Or it is just on the Video Input.
  • 2 more comments
  • Rommel Cana
    Rommel Cana Aug 23, 2010
    • If it happens on both, check the Vertical Circuits
    Circuits that is connected to these yoke:
    downwards to the Board., it could be a bad capacitor , a diode , a cold solder joint
    or from the Vert IC itself.
  • Rommel Cana
    • If it is only on TV programs, then you might consider having an external tuner instead, than
    just having your unit for repair, It would be cheaper also if you still have the VCR that have
    built in TV Tuner. Connect it as how you would connect a DVD or VCD player.
    • Check also the TV system , it could just be accidentally SET to PAL. Select NTSC , if you
    are in USA
  • Rommel Cana
    • Your Unit doesn't need repair, if you want to.
  • Rommel Cana
    • Connection will be like these:
    • But if you can DIY , check on 3.58Mhz Crystal ( tuner ) VIF section near the Color System
    Circuits or have it resoldered.
Samsung 55" blurry picture and words are blurry...netflix comes in perfect...whats wrong
Is it a 3D TV. Try changing the refresh rate in the Picture Menu 60HZ is normally the standard but try others. Or if you're TV has Auto Motion Plus options you try turn it on it can be found in your television's menu under Picture Options. The Auto Motion Plus menu contains several options, including On, Off, Clear, Smooth and Standard. If changing your Auto Motion Plus options doesn't correct blur, call Samsung.
Jan 24, 2015 | Samsung Televison & Video
My tv has double color and tthe picture flips then turns itself off.
sounds like a short in the convergence circuit based on model number listed here,
Apr 17, 2012 | Toshiba 43H70 43" Rear Projection...
Tv screen became very light; picture delay which causes double/triple image and in slow motion.
Is this LCD Flat panel TV? It sounds likelit has bad T-CON board, see example here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 03, 2011 | Haier Televison & Video
Why is it that whe i play a video on you tube with my notebook with windows seven starter the sound is ok but video come like pictures
The computer requires motion picture enhancement programs to generate continually. For example, networking streaming picture enhance mentionable are flash player, shockwave player, direct x players or active x players. Search the internet to acquire and download comparable media codes mentioned to achieve motion media experiences. Once downloaded, flash player would acquire the entire media to broadcast continually also called streaming without breaks.
Feb 02, 2011 | YouTube Videos
Powering on but no picture or sound! what could be the problem!
assuming its just a simple issue start with double checking all connections on ps3 and tv.
Next make sure the settings are correct on the TV, I.E. right AV output.
Next hold down the powerbutton and continue to hold it down after it turns on til you hear it beep this will reset the video to default. Being you are not getting sound (assuming not using hdmi where sound/video are from same cable) this should fix it. let me know please if any results
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
Lg 47 lg 7000 lcd. How to quit tue motion demo? please
I am pretty sure you can press menu and go to picture than pick one of your viewing modes, than do avanced settings and scroll down, you should see tru motion and other settings, try doing this.
Apr 04, 2009 | LG 47LG70 42 in. LCD TV
DVD picture looks odd
Most high end and larger Samsung TV's are equipped with what is called auto motion detection, more or less the TV tries to anticipate where the movement is going to be. The reason your getting the trippy pictures is because the tv's refresh rate is probably twice as fast than the source feeding the video.
To turn this off just go to your menu and scroll down and choose picture option and find auto motion and turn it off there it is problem solved! It won't hurt anything and can be turned back on as easily
Mar 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
Hitachi Mo# 53uwx10ba double image
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
