Question about Toshiba Satellite A135-S2276 Notebook
I have a toshiba sat 35x0360 it has usb port no parrell port. i can't print my dos program. help
    President:
  • 2,571 Answers
Parallel ports have not been use in a very long time.
You can buy a usb to parallel adapter, just google or try amazon
Posted on Aug 21, 2010
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
NOT PRINTING OUT OF DOS PROGRAM
The problem is, the DOS program tries to print to LPT1, which is your parallel port. We need to redirect this to your USB Port. First, you have to set up printer sharing: Go to Control Panel | Printers | Your printer and share the printer. Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type go to Start | Run and type in: NET USE LPT1: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES That should do the trick, unless there's a driver problem, which is unlikely for a dot matrix printer. If that doesn't work, let me know and I can troubleshoot further.
Sep 09, 2007 | Panasonic KX-P2130 Matrix Printer
I can't print
if your using printer with usb cable
dos print will not work
try lpt port
or
try dos to usb softwre
Nov 19, 2013 | Epson FX 2170 Matrix Printer
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
Panasonic kx-p1121 using usb port.
hi solution may be simple:
back in the times of DOS USB was not up to date, so older applications(if run in DOS mode) may not b ebale to address the usb port.
Sep 08, 2009 | Nikon COOLPRINT Thermal Printer
I want to print from a dos program set on lpt1 to a usb printer -how?
The information at this link should help http://www.dos2usb.com/download.htm Its a program that redirects your print jobs to a USB port.
May 02, 2009 | Computers & Internet
Landtech dos for windows - new systems (XP) need to windows
you can get a hub for the lpt and usb try www.tigerdirect.com
Jan 25, 2009 | Intuit QuickBooks Pro 2008: Windows
Print to a USB port in DOS in Windows XP
This is an interesting question .... I never thought much about using a USB printer in DOS!
Well ...this is probably the easy fix :
Program called dos2usb which claims to do exactly what you want (15 day free trial download ....$19.99 to buy the program)
The harder fix that won't cost anything is to do some network jiggery pokery to redirect data sent to a parallel port to a usb port. Here's a link on how the folks at Dataflex did it :
http://www.decompile.com/dataflex/tips/usb_printer.htm
Jan 01, 2009 | Microsoft Windows XP Professional
Foxpro dos programme not printingin usb printer laserjet cp1515
You can access your printer connected to USB port with loop back configuration and print from DOS.
Not only that, you can also print to a printer on the network
Try
Net use lpt1: \\Comp name\ printer name /persisten:yes
Dec 31, 2008 | HP PSC 1610 All-In-One InkJet Printer
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Toshiba Satellite A135-S2276 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
