Question about Compaq Computers & Internet
Laptop will not charge. Brought new battery and and it did charge for a while now it will not charge at all. Changed power cords and still nothing. Need all programs for classes. It's urgent that nothing be disturbed.
    Sergeant:
  • 238 Answers
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Posted on Aug 21, 2010
Samsung 145
Dear frnd,
Probably its battery problem but before change the battery you have confirm first its battery or Adopter problem. you need do first check the adopter to another laptop which has same charging pin . if its doesn't work with another laptop then you change the adopter but if the charger works with other laptop then you need to change your battery. try it..
Jan 15, 2014 | Samsung N145-JP01US Netbook
Power cord light is yellow not green
Hello,Yellow means your battery charge is low, and it is being charged.
Green means you have a full battery charge.
So probably it seems your battery is out of juice. Keep it on charges & it should be fine.
If there is nothing changed, you may need to exchange the laptop charger.
Lenovo IdeaPad Z570 AC Adapter
Hope this helps.
Nov 01, 2012 | Lenovo IdeaPad Z570 Notebook
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
Dead battery
Google replacement batteries for your (brand / model) laptop or try their (laptop) website support
Aug 13, 2011 | Computers & Internet
Battery wil not charge. Ordered new battery, still will not charge, brought new power cord and still will not charge.
Internal issue, if it is possible check to make sure there is power coming out of the prones where the battery sticks in, if you have a tester you will be able to test if there is power going to the battery.
Dec 31, 2010 | Acer Aspire 6920 Notebook PC
Hello, I am having problems with my Compaq nx6110 laptop not charging. It is not the battery, as I replaced it at the end of December. The problem seems to be that the charge isn't reaching the battery,...
If you remove the battery, does the AC Adapter power the computer? Does the laptop have a barrel type power connector? I have replaced several power connectors for broken center pin. Does wiggling the power connector affect the charging light?
Mar 20, 2010 | HP Compaq nx6110 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
My computer is dead and it will not charge at all
I am assuming you mean laptop. If that's the case, your charger should act as a power cord. If you just bought a new power cord and it's still not coming on, bad news for your laptop. If it turns on with the power cord but dies as soon as you unplug it, sounds like you may need a new battery. Check with your laptop builder for info on getting a new one.
Aug 10, 2009 | IBM (92P6581) for ThinkPad T40 (92P6581)...
Toshiba wont charge
Sound like you may have the wrong power cord for your unit. The original power adaptor for the A105 is 75W (15V x5A) Auto sensing 100-240V/50-60MHz frequency input. If you got a replacement adaptor, I would reccomend a 75W or higher adaptor. (A new opposed to a used one.) Good Luck.
Feb 02, 2009 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
