Question about Night Owl Optics NOTG1 Goggles
Need to buy a on off switch - Night Owl Optics NOTG1 Goggles
    Scholar:
  • 97 Answers
Digikey.com search ther catalog thers no parts listing for thease units and not a regular switch and order what you need ther hope this helps
Posted on Aug 31, 2010
My trigger switch works sometimes and then other times the trigger switch doesn't work and my light goes dead. Do I need to replace the switch and if so can you buy them.
Either the switch is bad or the wires going to/from the switch are loose and making intermittent contact. You need to open it up to see whats happening.
Feb 27, 2015 | Channellock Channel Lock 4v Dual Driver
Do I need to buy a software license for WS-C2960S-48FPS-L?
No. WS C2960S 48FPS uses the Universal image, but no license is required. The feature is bound to the hardware model type and cannot be changed. For convenience, a single software image is used for all Cisco Catalyst 2960-S Series Switches, regardless of whether they are a LAN Base or LAN Lite model.
Jan 20, 2015 | Cisco Catalyst 2960 Ethernet Switch ...
Should I buy a new antenna wallplate for my rv? Current wallplate does not have an on/off switch mentioned by some bloggers. I wish to improve my reception.
Some HD antennas , in RV have a signal booster which enhances the signal . these may be the ones with the on and off switch. These run off either 12 or 120 volts. If replacing the head/ antenna buy one with a signal booster. It usually come with it's own switch or buy one for it at radio shack.
May 07, 2014 | Winegard RV7042 Wallplate/power Supply...
How to change the oil pressure on 96 ford taurus
The switch is standard pipe threads with some threadlock on it.
You can buy a special socket when you buy the switch which makes it easier to R&R, or you can use a deep socket that fits the switch.
Mar 04, 2014 | 1996 Ford Taurus
How to Buy Cisco switch, any Guidelines ?
visit http://ciscosfp.blogspot.com there is the topic to tell you how to buy the Cisco switch, you can't miss it
Jan 24, 2014 | Computers & Internet
Hello, I currently have a celing lamp in my kitchen. There is a little cord you pull to turn it off. The onlything is, is that the cord is not working and i dont know how to turn my lamp off if not to...
The lamp has on-off pull-chain switch.
You can buy replacement pull-chain switch at hardware store.
Buy the pull-chain switch that has two wires.
Buy two yellow or orange wire nuts.
Switch off breaker.
Take apart light.
Remove old pull-chain. Strip back the wires if needed, twist wires together.
Connect new pull-chain switch using wire nuts.
Sep 22, 2011 | Electrical Supplies
Got new dvr box (not HD connection). had to use inputs that xbox was connected to on tv for my dvr. how do I connect the xbox 360 now so that we can use it without switching out the connections?
There are a couple ways to do this. The cheaper way is to buy some RCA Y adapters. You'll need one for each input (3, probably). Plug the male end into your TV, then plug the (yellow, red or white) cable from the XBox and DVR into the other ends of the cable. The downside of this is that you'll need to turn off the box you're not using in order to see the screen OK.
The slightly more expensive way is to purchase a switch box from Best Buy or Radio Shack or any where on the internet. The switch box will work like the Y adapters, but you can have both boxes on. If these are the only two devices that you need to use, then you only need a 2 way switch. Buy the switch and three RCA cables. Plug the RCA cables into the back of the switch in the output holes, and plug the other end into the TV. Plug the DVR and XBox cables into the input sections of the switch. Then you press one button for DVR on the switch and the other button for the XBox.
Oct 02, 2010 | Microsoft Xbox 360 Elite Console - Black
Wsm2400 fd652357e dryer on/off switch is broken, I need a new switch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 03, 2010 | Dryers
Need substitute switch part for sears saw
Sorry , but go buy a new saw. Your not going to find an aftermarket
dealer that carries this switch.
Trying to rig some other switch is not worth the trouble over buying a new one. If the switch is not available, then the saw is old.
New
Craftsman Evolv 12 Amp 7-in Circular Saw 35.00 dollars.
Feb 15, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Night Owl Optics NOTG1 Goggles Logo
99 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
Ted Maxwell
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
