Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How to change the security code on a keypad for the garage door opener
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Aug 23, 2010
My Liftmaster Security wall mount keypad won't open the garage door. It will make it close but won't open it back up. I replaced the battery but it didn't change anything. The keypad will blink for...
You might try programming it but I think it is bad.
To program locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trying to reset code for a Garage Master Security + garage door opener - with no luck -
If you are trying to reset the code for the keypad, locate the smart/learn button on the rear of the motor unit. Press and immediately release this button and then walk over to the keypad and key in any 4 digit code you like and press enter.
If you are trying to reset the code for the hand remotes, you can't.
May 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to reprogram keypad for garage door opener
On the rear of the g. door opener, there is a learn buttom.
The first step is to push this button in.
Then go to the remote and enter the new code you want
Press and hold the enter button.
The lights will blink and or you will hear two clicks.
The code you entered should be learned and ready to use
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Two codes open door
You must hold that red button in for 6 seconds to erase the memory. Just remember you will have to program your hand remotes plus the wireless keypad.
Aug 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I change my garage code to my chamberlain keypad?
Locate the smart/learn button just to the left of all those white wires. Press and immediately release it and then key into your keypad any 4 digit code you like and press enter.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lost keypad security code
On the back of your motor unit near where all those white wires go you will find a button. Press and immediately release this button and then walk over to your keypad and enter the new 4 digit code you want and press enter. Should do it.
May 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad will close door, but not open it!
Try changing the battery and reprogam the keypad. The code remains active for about 30 sec. after it is entered into the keypad which allows you to press enter to change direction of the door
Jan 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
49 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
