Question about Dell Dimension 5100 (D51L1) PC Desktop
My Dell Dimension 5100 computer fails to start when pressing the on/start button. There are no lights illuminated/blinking at the on switch. After considerable troubleshooting I discovered I can start the system by momentarily grounding the green wire (power supply start) on the 24 pin power supply connector and then pressing the start switch. Does this mean the startup logic circuit on the motherboard has failed and the motherboard must be replaced?
  • rgh1016 Aug 22, 2010
    It appears there is a logic circuit between where the on switch ground comes into the motherboard (Connolly E 187242 F2) and where it applies a soft start start ground signal to the the green wire on the 24 pin power supply connector and this logic circuit is powered by the battery on the motherboard.
    When I removed the battery, cleaned it, and re-installed it, the computer powered up correctly. I powered down, removed the power cable, reinstalled it after the green light on the motherboard was extinguished, then used the on switch to start the computer and it powered up normally. I did this numerous times to just make sure it wasn't a momentary fluke.
  • rgh1016 Aug 23, 2010
    The following supplements the original problem description:
    If I let the Windows power down and shutoff the computer in a normal manner and don't remove the power to the computer, I can start the computer by pressing the power-on button on the front of the computer. However, if I remove the power to the power supply after the machine has been powered down, I can only re-start it by momentarily grounding the soft power line on the 24 pin power connector. Replacing the battery did not have any effect.
SOURCE:
SOURCE: Computer fails to start
I'm reasonably sure that it is a bulging or bad capacitor issue. We have had Dell replace a large number of motherboards on SX270 and GX270 computers, due to underpowered or counterfeit capacitors on a large batch purchased back in 2005. The capacitors swell or burst until the computer will not turn on anymore. You'll get the amber light inside the unit, plus a green light on the power supply, but the computer will not power up. You can try the solder technique, but you'd be better off replacing the system board, if possible. Happy trails!
rgmckenz
Posted on Nov 28, 2007
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
APremkumar
  • 564 Answers
SOURCE: Dell Dimension 5100 No Power No lights
Hi Eric,
Don't Worry we can fix this this problem.
This seems to be no power issue.
Just mail your email address and number to [email protected]
Thanks, Prem
Posted on Mar 08, 2009
SOURCE: connecting front panel leads of generic case to 4600 motherboard
-MrSlickShoes
Posted on Mar 20, 2009
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
I have a dell 5100 laptop. This morning i removed a program through add/remove programs. The computer need to be restarted. During the restart I left and came back the power light was blinking so I pressed...
Our expert technicians provide you dell tech support for desktop, computer, laptop, printer, drivers, etc. Call at our number 1 (800) 204-4427 and get 24X7 quality services.
May 19, 2017 | Dell Inspiron 5100 Notebook
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I have a dell dimension 2400 with a blinking amber light what do i do
The blinking amber light on the dimesion 2400 generally means that the power supply on the system has gone bad. Switch off the system and disconnect the power cord from the back of the system . Press and hold down the power button in the front for 10 seconds.
Reconnect the cable back and try powering on the system.
If the same ,fails you would have to take the system in for repairs
Thanks for using Fixya
Proton
Sep 03, 2010 | Dell Dimension 2400 PC Desktop
My Dell dimension 5100 on switch will blink yellow but will not boot up (on). When it did work, the switch would change to green.
boot files are corrupt or missing....
only repair of OS will rectify...
else
u need to reinstall OS...if
u have more then one logical partitions i.e. C:, D:, D: drive etc in ur HD then u can install one more copy of OS in either D: or E: and then when computer starts/boots u can chose from the multiple OS windows install to boot from.
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer won't start
Can you see a green light on located on the mother board ? I had the same problem with mine right after the warrranty was off, The mother board failed, But you should make sure thats it first by making sure everything Inside of the computer is tight and secure.Unplug and make sure there is no power on and unplugged,Before you touch anything inside your computer discharge any static electricity by touching the metal on the inside of the tower. The Memory modules Make sure that they are pushed in securely in there slots and video card is Pushed in and tight, and any other extras you may have plugged into it, After you do all that put everything back and try to reboot see if that get you up and going. If not let me know I can Help You fix it or repair it myself if you would like, just leave message here or email me. [email protected] Happy Holidays
Dec 15, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
153 people viewed this question
Ekse
Clive
Clive
