Question about Smeg WDI12 Front Load Washer / Dryer
Smeg wm63141bk Door closes okay, but message appears all the time saying "close the door"
  • 10 Answers
SOURCE: The oven door won't close
the clips on these oven are canyilver type they can move out of position if opened abruptly .to refit correctly lift door upwards while pushing the bottom of the door inwards.you should feeel a strong resistance from the door springs.there should be a notch n the bottom of the hinge this should slot over the oven frame.if this does not solve the problem then the springs have probably gone on the hinges and will need to replace both hinge assemblies
Posted on Jul 11, 2008
  • 87 Answers
SOURCE: Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Posted on Jul 13, 2008
SOURCE: Smeg dishwasher L5 eco when
brought a new dishwasher
Posted on Aug 31, 2008
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
ltldab
  • 152 Answers
SOURCE: smeg washing machine WM63141BK blowing electrics
SOMETHING IN THE WASHER IS SHORTED TO GROUND
Posted on Feb 26, 2010
Will these doors interchange, on these models
doubt it but measure both and see if they are close
Apr 21, 2015 | Smeg Ovens
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
The oven locks, it starts beeping and the panel says F5E0. How do I remedy this problem?
F5 - E0 Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door) 1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes
Nov 06, 2010 | Whirlpool RF365 Electric Kitchen Range
Range with Error Code F5 E0
HI.The Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door)
1. If door latched:
  4. Re-apply power.
Jul 18, 2009 | Kitchen Ranges
The door gasket on my Smeg fab28 is not sticking to the fridge properly. The Smeg only wants to sell me a new door. What to do?
I have a need trick to solve this problem
you door wont close all the way probably because to inner side of the door (the hinge side) the gasket is touching the fridge frame and been bend back .
or the top or bottom is miss align
the solution is simple
loose up the bolts than hold the hinges
and use coins as shims
"yes" "coins" nickles pennies or quarters
slide then in between the hinge and to bridge body and will give the gasket he necessarily space to close properly, may take several times on till you get the right combination
and make sure is no gap left after that
It has work for me lots of times.
good luck :)
Jun 10, 2009 | Refrigerators
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Smeg Fridge light
Jul 04, 2008 | Smeg FAB28
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Smeg WDI12 Front Load Washer / Dryer Logo
Top Smeg Washing Machines Experts
Tom Chichester
Jorge Rendon
Jorge Rendon
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
