FixYa.com
Tags:
Whirlpool GU2400XTP Built-in Dishwasher
Sandy glasses
posted by treefroggy on May 03, 2008
The dishes on the top rack come out with a sandy residue on them....we have tried running it with the jet dry dishwasher cleaner, the vinigar and baking soda...have taken apart and checked all filters and water supply...no help with any of that. I also wonder how much water should be in there when it is running...shouldn't it cover the heating coil in the bottom? My water level is just below the coil.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 22, 2008
Not Rated (0)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 287 votes
Are you making sure your heater is ok??Water temp should be taken and be 120 or hotter.If its not turn up water heater temperature.If heating coil is not working replace it.It provides the heat to the D/W and aids in the heated Dry cycle.The solution for spotted/foggy glass problems all  start with making sure your water is Hot enough.Rinse aid is the second.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
Water Stayed in dishwasher
Could you please advise why... Answer This...
Dishwasher problem
Hi My dishwasher will fill with... Answer This...
my dishwashers not working
hi. when i put it on for a... Answer This...
WHIRLPOOL QUITE PARTNER ii
it just quit. no lights... Answer This...
clean light is blinking
clean light is blinking. Manual... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
