Question about Singer Sewing Machines
I can't get the needle to pickup the bobbin thread
    Genius:
  • 1,788 Answers
Sounds like the needle is not inserted the right way or the thread is unwinding in the wrong direction. Go to Singer.com and download a free manual,
Posted on Aug 21, 2010
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
The needle will not pickup the bobbin thread?
First, make sure to install a brand new needle. Damaged needles frequently will not pick up bobbin thread.
If a new needle doesn't work, then most likely the machine has a needle/hook timing issue (the needle is arriving at the bobbin at the wrong time to connect with the bobbin thread).
There are many web sites and videos explaining sewing machine timing. Or you can take it for service.
sewing machine timing Google Search
Jul 25, 2016 | Sewing Machines
The needle won't pick up bobbin thread on mu Elna Air Electronic SU
Has this just started after a jam up? As it's usually a symptom of timing being out.
However first check needle is in right way, flat shank to the back and threading is correct including the take up lever.
If no joy then mechanic service time
Apr 18, 2014 | Elna Sewing Machines
Bottom thread will not be pickup
There is loose thread hanging from the lower bobbin, isn't there?
Dec 12, 2013 | Necchi 4595 Mechanical Sewing Machine
I have a euro pro x I cant get the upper thread to pick up bobbin thread I have tried everything please help
Are you holding the end of the top thread whilst trying to pickup the bobbin thread? Put a BRAND NEW needle in - it may look OK, buy the slightest bend will be an issue. Is it the CORRECT needle for you machine? - check your manual. Is the bobbin in the case correctly and feeding out the correct direction? ...... timing may be out
Oct 18, 2013 | Sewing Machines
I cant get upper thread to pick up bobbin thread
Are you holding the end of the top thread whilst trying to pickup the bobbin thread? Put a BRAND NEW needle in - it may look OK, buy the slightest bend will be an issue. Is it the CORRECT needle for you machine? - check your manual. Is the bobbin in the case correctly and feeding out the correct direction? ...... timing may be out Good luck!
Model 4075 white sewing machine
Are you holding the end of the top thread whilst trying to pickup the bobbin thread? Put a BRAND NEW needle in - it may look OK, buy the slightest bend will be an issue. Is it the CORRECT needle for you machine? - check your manual. Is the bobbin in the case correctly and feeding out the correct direction? ...... timing may be out. Good luck
Oct 13, 2013 | Sewing Machines
My kenmore sewing machine won't pickup the bobbin thread
if you've tried changing the needle & tryed rethreading the machine
then it's possible that the machine need to have the timing checked
Oct 15, 2012 | Kenmore 11206 / 11306 / 11506 / 11606
Bobbin holder clicks when needle goes downward. Needle unable to pickup bobbin thread
Check your tension. Also be sure your machine is threaded correctly.
Jan 15, 2011 | Singer 2259 Sewing Machine
Bobbin thread not coming up
You need to do the first pickup by hand. Lower the threaded needle by using the hand wheel not the foot pedal, when it comes up, catch the needle thread carefully and pull up. It should bring the bobbin thread with it. Now you can start sewing. I hope.
Dec 18, 2010 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
20 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
