Question about Maax Home
I have a Maax Tigress shower. This will be 3rd time I've taken shower door frame off base to recaulk. I have leaks where frame meets base. I don't think base is stiff enough, because I can feel it flex when I stand in shower. This is probaly breaking the seal of silicone. Anyways I've tried GE Silicone II, and Mono Silicone, and I used a very liberal amount... Now what?
    Scholar:
  • 67 Answers
If the GE Silicone was used first then this may be the cause. For some reason the GE formulation does not adhere very well to new plastic/acrylic, however it does very well on most other surfaces. The mono brand is better for plastics/acrylic. If all of the GE silicone was not removed before the mono was applied then the mono formulation would not stick very well to the GE silicone that was not entirely removed. Unfortunately there is no easy way to do this other than with a plastic scraper tool and lots of elbow grease. Rubbing alchohol can be used to soften the silicone slightly and will not damage the acrylic, aluminum or glass. If the mono was applied first then the flexing will be the problem. The only solution to a flexing problem is to remove the shower unit and reinstall the unit in either a morter or sand base to provide more support for the shower unit. If you use a morter base ensure there is a vapour barrier installed between the morter and the shower unit as the chemicals/minerals in the morter will degrade the shower base over time. The downside to morter is that it will not flex and may cause cracking over time if and when the house shifts. A sand base will shift with the house.
Posted on Aug 21, 2010
  • 6 more comments
  • tsgr8deals Aug 21, 2010
    Thanks... Your absolutely right about the GE silicone it did'nt stick at all to the acyrlic.I used the Mono 1rst and the GE 2nd .And I did put base in mortor bed about 2 -3 inches thick, but the base has 5 inch legs that flex where attached to acrylic base. I guess using a polyurethane caulk just between the frame and base is out of the question? Since I've read its not mildew resistant.
  • John M Aug 21, 2010
    Polyurethane caulk is more designed for masonary and concrete applications. I'm not sure what it would do in contact with glass, rubber and acrylic. If you are caulking both the inside and the outside of the unit, try running the bead on the outside of the unit only. If you had caulked on the inside as well the water could be wicking through the bead at the glass through capillary action. It wouldn't hurt to give the folks at Maax a call as they have a pretty good reputation for customer service and may be able to suggest something I haven't thought of. http://www.maax.com/
Shower installation instructions
look at the new frame to see how thick it is
Feb 01, 2014 | Maax Plumbing
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
Maax neo round stall leaks where base meets wall
Many times there are small cracks in the panel or the base. It may not be able to be seen until someone is standing in the shower.
Nov 04, 2012 | Plumbing
Maax neo round shower stall continues to leak at bottom where it meets wall. Keep recaulking. Same results.
Many times there are small cracks on the material, it can be hard to see but opens up when someone is in the shower.
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
Where can I find shower door rollers for a maax shower door? Thanks.
amazon is one of the best places for purchasing your shower door rollers. Click here Amazon com shower door rollers and choose the best one (many of them are compatible with maax shower door), but anyway, before order something contact the seller to be sure. There's a plenty of rollers, so take a look.
I hope this was helpful.
enjoy
Mar 05, 2011 | Home
Ihave a shower with sliding Maxx doors. The bottowm of theframing (iguess its the drain tray has come use from the shower unit. Where can I get instructions how to reinstaal? What is the best way to attach...
I pushed mine back on using the rubber insert to hold it in place. Th bottom came lose, I opened the door and it flew open and shattered in millions of small pieces. A blood mess! This could be very dangerous, I was only cut up a bit. Am looking for a replacement. Be Carfull!
Aug 04, 2010 | Maax Home
Home Logo
374 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
