Question about Hoover AAA160 Front Load Washer
Have just moved a 1000F, but transported it on its back. It won't work. Is there a reset button anywhere that we could operate?
  • grahamesteel Aug 25, 2010
    Yes, the solution is very helpful. I am technically/manually dumb, but at least I now know what to look for when I call a local tradesperson.
    Many thanks,
    Grahame Steel
    Thank you. As a technically dumb person I will need to call a repairperson. At least I now know what s/he should be looking for.
  • Hoover Master
  • 12,061 Answers
Service.hoover.co.uk/manuals/pdfs/AAA160.pdf
Your manual is above,
What has happened is the Float switch, has jammed and this is because it was tilted back wards. You will need to free this float, you will have to dissemble the overflow container, and reset the float.
Posted on Aug 21, 2010
How can I fix this???
See if you can leave ideal to adjust its performance and try turning it off after about 30 mins to 40 mins
Jun 12, 2013 | Audio Players & Recorders
My tablet keeps on going back to the loading screen and repeats that
You will need to reset the machine to factory settings by holding in the "Reset" button with the power on. Then just wait until it reboots. If this doesn't work you may need to get the Operating System re-installed.
Feb 18, 2013 | Irulu Black 7 Inch 2gb Mid Google Android...
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
I have a Sharp 980 A microwave which has been working perfectly for the last few years. Now we've recently moved to another place and when we tried it a week back, there was arcing, without any metal...
It was probably some damage during the transport. A microwave is an extremely dangerous appliance. Mu sincere suggestion is that you take it to a qualified repairman, have it repaired and ask for a certificate to verify that there is no radiation leaks anywhere.
Apr 02, 2011 | Ovens
Won`t play movie, skipping sound.
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shiney. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not applie to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laserhead and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
May 09, 2009 | Mintek MDP-1815 Portable DVD Player
DVD player plays 10 minutes and then freezes screen.
You may have a problem with the transport of the dvd laser. Open the compartment that you place the dvd into. You will see the spindle,the laser lens and the transport device that moves it during operation. The transport system operates on system of gears and drive rails. You must check and clean the drive rails and gears. Use a can of compressed air and blow all the dust and debris from the dvd compartment. Then use some cotton swabs with a small amount of isopropyl alcohol on the tips and clean all the rails and gears. Check the transport action by moving the transport to its most outer position and back to its most inner position. The action and travel of the transport on the rails should be smooth and easy. The gears should be clean and move easy also.These parts will require cleaning every month or so . Remember do not touch the laser lens with your hand. You should also check the lens it should look bright and shine. If not try cleaning it with a cotton swab and a small amount of alcohol. Rub the lens gently back and forth unit it is bright and shines.Now you can try playing a dvd and see if the player works properly. If this does not fix you problem. You can reset the dvd player to the factory settings.1.Press the setup button on the remote control.2.Use the left and right arrows to highlight the preferences page.3.Press enter to to enter the preferences sub-menu.4.Use the up and down arrows to find the default function and press enter. You now have reset the dvd player to factory settings Now again play a dvd to see if the player is functioning normally. If not you may have a more serious problem with the drive motor or power supply circuits. you can call Insignia customer service support at this telephone number.1-877-467-4289. Give them the model number of you dvd player and tell them the problem you are having with the loss of operation during the playing of a dvd. They will be able to tell you how to get testing and service for you dvd player. I hope this information helps you with your problem.
Feb 07, 2009 | Insignia NS-8PDVD
Whirlpool washer noise
moving it on side might empty gearcase oil, any yellowish oil drippin gout of anywhere? hard to tell about hte metal movig around, its quite normal for machines to move around quite a bit on the inside
Mar 11, 2008 | Washing Machines
Power problem
Hi, Try logging your post on the Kirby Trading Forum at Kirbydirect.co.uk - you'll be sure to get a reply. John
Aug 03, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Hoover AAA160 Front Load Washer Logo
185 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
