Hoover VH W654D-80 Showing E11, What is this mean
2 Suggested Answers
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
Hi what does e11 mean on my hoover dynamic 6+5 wdyns 654 d mean pls?
Code E11 indicates an open circuit between the heater and the control board. The code also can indicate damaged wiring between the sensor at the top of the drum and the control board. The wiring can be damaged by drum rotation.
Feb 09, 2015 | Hoover Washing Machines
WHAT does E11 meens washer does not take in water
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF705BZHS, is not filling with water and showing an E11 error code. The E11 code means that your washer is taking a long time to fill. First, make sure that the incoming water faucets are turned on. Next, you will want to make sure that the pressure is above 30 PSI. I suggest resetting your washer, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire AFFINITY WASHER ATF705BZHS FOR...
I HAVE HOOVER VH W 644 D what does E 11 mean
Hi, you've posted your query in 'computer motherboards', try reposting in 'domestic appliances'
Nov 29, 2012 | Computers & Internet
Hoover wdyn 9666pg-80 error code E11
I fixed ours! here is a video of how i did it, it shows where the wire snaps and what part the wire connects to:
May 11, 2012 | Hoover Washing Machines
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
Error code E11 on hoover washer dryer vhw854d
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Nov 12, 2010 | Hoover Washing Machines
My hoover washer dryer VHD is showing a fault E11 and the washing in the machine is still wet
Apr 10, 2010 | Candy Washing Machines
No manual for hoover vh w8560 washer-dryer
Hoover have a download section on there website for user manuals visit www.selfix-uk.co.uk and click on 'User Manuals' for their link.
Mar 03, 2010 | Washing Machines
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
