Question about Schwinn 26 M Searcher
NEED TO REPLACE MY CRANK GUTES - Schwinn 26 M Searcher
    Genius:
  • 1,788 Answers
If, you mean a bottom bracket kit, it is best to go to your local bike shop and pay to have it rebuilt because it requires special tools that aren't used very often. Trying to make do with the wrong tools will get you in trouble, ie crossthreading for one and stripping the nuts.
Posted on Oct 07, 2010
Need to take the shroud off recumbent 230 Schwinn?
Unless you have broken off the crank arm there should be no need to replace it. However, if you truly need to do so try calling a Dick's Sporting Goods store, as they sell that item.
Sep 27, 2016 | Cycling
Stripped bicycle pedal
Better replace the pedal and most probably the crank arm as well. Sometimes a new pedal can cut the threads true again on the crank arm but the crank arm may need replacement too, depending on the damage. Remember to fit the correct side pedal. The pedal threads differ between left and right and pedals are usually marked "L" or "R".
Jan 04, 2014 | Huffy 26" Womens DS-7 Dual Suspension...
Ignition failure
Replace the crank sensor, crank sensor is for spark, cam sensor is for fuel. let me know how you make out.
Dec 04, 2013 | Hyundai Cars & Trucks
Error code P0320
Its a crank sensor code.
If you have a 4.0 liter replace the crank sensor adn you should be good to go. It is possible that you may also need to replace the distributor sensor but I wouldn't worry about it unless the code comes back after replace the crank sensor which is more common to fail.
if you have the 4.7 Liter replace both the crank and the cam sensor. You just have to trust me on this one.
Mar 09, 2012 | 2001 Jeep Grand Cherokee
Left pedal broke can i get replacement?
All depends on if you stripped the crank arm, you may have to replace your crank arm if you rode with a loose pedal. Pedals are sold in pairs, and there are 2 sizes, a one piece crank is 1/2" and 3 piece crank is 9/16", take your bike to the bike shop and they will tell you if you need a new crank arm or not. It will do no good to just replace your pedal if there is a bad crank arm thread, it will not hold.
Sep 26, 2010 | Cycling
How too replace connecting rod on a ttr 125l. I have a 2001 ttr 125 with a seized conn big bearing. and I would like to know the proper way of splitting the crank too replace it
The top end comes off then the left and right side covers, flywheel, clutch and shift shaft. Now a case splitter is used to split the center case halves. To replace the bearing you will need a hydraulic press to disassemble and reassemble the crank halves. If the bearing is seized you should replace the bearing, crank pin and the connecting rod. The crank must be realigned using twin dial gages. Personally, I suggest a new crank assembly be purchased from www.babbittsonline.com ( $241 ). I would replace the crank end bearings at the same time and also the sprocket shaft outer bearing and seal. Please rate my answer.
Jan 03, 2010 | 2002 Yamaha TT-R 125 L
Need to replace crank sensor, cant get it off to replace it
sometimes they have to be drilled out so you can replace them
Jan 31, 2009 | 1992 Chevrolet Lumina
Crank position sensor
you just need to replace the sensor. it is independant of the distributor
Sep 12, 2008 | 1992 Honda Accord
Schwinn 26 M Searcher Logo
46 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
