Toshiba model cf35d50 tv how and what type of speakers are require for external use the main tv speaker is blown
My Toshiba model number CF35D50 has lost the red in the picture. How do I fix this?
Posted on May 04, 2011
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
Very low sound on Element 32 inch model no ELCHW321
A couple of possibilities, both will require repairs to the tv. Either the speakers are blown, or more likely the speaker amplifier on the main board is bad. Both are repairable if you want to spend the money. It is probably cheaper to buy a new 32" tv than to have your tv fixed.
Aug 02, 2016 | Element Televison & Video
Is there any way to fix blown speakers on toshiba TV/DVD Combo MD20F52?
Replace the speakers, or use external speakers if there is a place to connect them.
It would be unusual for more than 1 speaker to go bad at the same time.
I would suspect the sound amplifier inside the TV. If the TV has Audio output connections, you can hook them to anything in your house that has an audio input.(stereo, boombox, computer, etc)
Jan 24, 2015 | Toshiba Televison & Video
HOW a 36A41 model's External Speakers Work ?? ...
Your speakers may be plugged into outputs intended for connection to an external amplifier.
May 04, 2014 | Toshiba 36A41 36" TV
Toshiba tv speakers broken
You probably have a bad solder connection that has completely opened up...Or if you have a flat screen TV you will need to change the main board... Just get the model number and go to HERE for availability and part search. The main board has the audio circuits.
Nov 25, 2013 | Televison & Video
Plug in head phones to tv/no sound
If no sound from speakers or headphone likely audio circuit issue but check to make sure main speakers not switched to off or external.
Nov 04, 2012 | Toshiba 19AV505DB 19-Inch Screen Hd Ready...
Terrible sound, sounds like speaker blown. Got it 2 days ago.
If this is a "new to you" TV, keep reading. If it is a brand new TV, I'd be on the phone to the store to have a replacement ready for delivery / pick up. You do not want to be repairing a TV that is 2 days old.
The first thing to do is determine if the distortion is coming from the speaker or if it is on the signal going into the speaker. Do both speakers sound distorted or only one?
You didn't include the model number of your TV, so I can't speak to specifics. Look for a terminal on the rear of the set identified as "speaker" or "external speaker". If provided, there will be one set of terminals marked for the left and one for the right external speaker.
Connect a speaker directly to the terminals marked for either the left or right speaker (connect to the one that sounds distorted if only one of the built in speakers works correctly - other wise pick either speaker terminal pair.). Speakers that have RCA plugs on them, have built in amplifiers, require batteries or or to be plugged in to an outlet should not be connected here.
Alternatively, you could connect a pair of stereo headphones or earplugs if your TV offers a jack for them. It would have a headphone icon or say "phones" above the jack if one is provided.
Once connected, turn the TV on, lower the volume and set the TV to enable the external speakers / disable the internal speakers. This may be done via menu item selection or a small switch near the speaker terminals. Slowly increase the volume to listen to the quality or clarity of the sound coming from the speakers you connected. If they sound distorted, the problem lies with the audio amplifier in the TV. If they sound OK, then there is a problem with the speakers in the TV.
If you can't return the TV, you may have to see about using the left and right audio line out or HDMI jacks to send the audio to an external amplifier and speakers to hear the program.
I hope this was helpful and good luck! Please rate my reply. Thank you.
Apr 06, 2011 | Sanyo 42 in. LCD TV
Can i connect external speakers
gjrob,
You can connect external speakers with you model only if you have an external source of sound such as a receiver. This model does not have speaker outputs to directly connect speakers but it does have audio out connections that can send the sound from the tv to another source like the receiver.
On the back of your tv on the left there are connections listed under "Out". There is where you will find the audio out connections (red and White).
-Chris
Mar 02, 2010 | Toshiba 27AF41 27" TV
My Toshiba TheaterView has no sound or picture
You may have overloaded your audio output with the external speakers(impedance or short wire problem?)as a result the audio out i.c maybe damaged which in turn may have blown one of several fuses in the power supply.maybe regular GMA type fuse or picofuses,you can try replacing blown fuse but if they blow right back you`ll need the help of a repairman
Nov 02, 2009 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
