Question about Kitchen Ranges
When in the spin cycle the motor seems to start and stall rapidly.
  • Kitchen Ranges Master
  • 12,061 Answers
Well, when this happens, it is one of a few things, either, the actual motor's windings, are failing soon after it starts,(It overheats) or the Controller Semiconductors that switch the Motor ON, fail under load, and stop, driving the Motor. The only other way is if something is activating the Brake...
One must troubleshoot the issue to determine what is at fault.
Now really the only way to effectively do this is to obtain a service and repair manual,for your exact make and model, and follow the troubleshooting steps within.
If you don't wish to DIY, then please, first, ask for a "Quote" from your local Range Serviceman.
Posted on Aug 21, 2010
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
WHAT IS AND HOW TO DIAGNOSE STARTER DRIVE ON FLHTC 1340CC HARLEY
Hi Anonymous, it sounds the like starter drive/clutch has gone south, it has components inside, that when spinning, centrifugal forces cause them to grab or lock into permanently fixed counterparts. The gear only spins one way and locks the other way. If you have one that spins both ways it makes a noise like the starter is just spinning, it has failed and needs to be replaced. Please visit the web site below for more help. Good luck and have nice day. Harley Davidson Manuals Mark Workshop
2005 Harley Dyna FXDX starter replacement
Oct 22, 2012 | Harley Davidson FLHTC Electra Glide...
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
My aeg lavamat L14710 VIT only spins at a very low speed ! does this mean that the motor needs replacing ? how can I verify ?
Does the machine seem to be draining (pump running) fairly quickly as the spin cycle begins? If not, the machine will sense the high water level and prevent the motor from turning rapidly. Check the drain hoses and pump for clogs, pinched hoses, plugged filter, etc.. Hope this helps!
Mar 31, 2010 | Washing Machines
Spin no longer works.
check coupler sounds like it is broken,it is located between the motor and transmission.
Aug 24, 2009 | Whirlpool WTW5300SQ Top Load Washer
Motor will not start in slow agitate
I rewound electric motors in the past, in your case i don't know if its a armature motor it would have brushs. if it was if its without brushs, it would have two septrate windings one for spin, one for wash. the wash windings could be 'faulty',answer! try other motor! if you get one. let me know which motor it is Ire,Close. bye for now
Dec 02, 2007 | GE WBSE3120B Top Load Washer
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
