Question about Kodak EasyShare M1033 Digital Camera
When the camera gets turned on the shutter pops out as should be. But then immediately pops right back in and shuts the camera off
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 22, 2010
My Nikon L35 AF's shutter button won't pop back up when I press it down.
Hi Broderick,
You have some (dirt/ dust/ sand) clogged around the clearance between the shutter button and the camera body. If you are a DIY type of person, you can check and clean that dirt, other wise take it to a repair shop for proper cleaning.
Jan 14, 2016 | Nikon Cameras
I was in the middle of shooting a wedding, when suddenly my camera said that it was 'busy' - it was taking a while to go back to normal, so I decided to shut the camera off and just turn it back on again...
hi,
If the lens does not extend then it is possible that it has become jammed. Sometimes this can cause the camera to sense an error and shut itself down immediately after powering on.
There are other explanations for the behavior, but if the lens does not move this is the most likely cause. If the lens does extend but then the camera shuts right back off it is possible that an inner component such as the focusing element is not functioning properly.
Aug 24, 2008 | Cameras
Batteries are fully charged. I can turn my camera on and look through my pictures, go through all the menus, etc., but as soon as I hit the button to take a picture, the camera just shuts off. I can...
Possible that the shutter or the focus mechanism is faulty and will need to be opened. Only if you are competent must you attempt to remove the camera as the mechansim and circuit will be delicate which needs experience. Ohter wise the best option is to ask a reliable technician to assist in opening and checking for a locked mechanism. Possible that some link had come loose or some foreign dirt has clogged. Hope you try. Good day
Aug 13, 2010 | Cameras
Camera shuts off after hitting the shutter button
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 21, 2009 | Kodak EasyShare DX6440 Digital Camera
My lcd screen is blank but the camera acts like it is taking a picture. Cannon PowerShot S3 IS
Had the same problem with my S3 is and couldnt find any help other than to junk it and buy another camera. WAY too expensive to repair (out of warranty)
I found a post and this worked for me...just fixed it about an hour ago. Mine would show a blank screen on the LCD nothing thru the view finder other than the menu screen. Found out the shutter was stuck and that seems to be a common issue with these cameras. This is how I fixed mine.
1. set the shutter speed to the longest setting you can. I put mine on the TV setting.
2. close the flash and set turn off all of the functions you can to conserve the batteries.
3. take a picture and within 5 seconds open the battery door. Then close it back and repeat. Your trying to interrupt the shutter reset process thereby "unsticking" the stuck shutter.
4. If this fails then try LIGHTLY tapping the camera against a piece of wood, again to unstick the shutter.
Sounds like a bad idea but considering I had tossed my camera in a drawer and already replaced it, I didnt really have much to lose. I was pleasantly suprised to see that after about 15 resets (steps 1-3) and a couple of light taps, the camera is working good as new again.
Good luck, hope it works out for you!
Jul 11, 2009 | Canon PowerShot S3 IS Digital Camera
Camera will shut off then the shutter will close
Yes it could. It is possible a small dirt get on the side of the lense and it prevents the lense to close all the way in. Clean it up and while turning the camera off, push the lense in. Not too hard. You might have to repeat the step a few times. Do not drop your camera, if you did make sure you clean the sides of the popped off lense. If they did not help, some mechanical part of the lense is shifted or broken.
Good Luck
Jun 08, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
I have a kodak m1033 turns on then shuts right off
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
May 18, 2009 | Kodak EasyShare M1033 Digital Camera
Shutter release button is stuck
You have two choices 1. take it to a repair shop and get a quote[almost the price of a new camera I wager] 2. Try your self[bearing in mind that if you cant fix it you'll have to buy a new camera] Chances are the in dropping it the button has forced it self through an aperture in the casing so that it cannot return. If you have access to fine screw drivers[Jewellers/watchmakers]slack off the screws holding the case together- done take 'em right out just slack 'em-it might pop right back out- if it does tighten up.
May 06, 2007 | Canon PowerShot A75 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
