Question about Kodak EasyShare One Digital Camera
I have my 3rd kodak easy share camera. The last 2 have had the same problem. When turning on the power it doesn't fully power up. The lens comes out, the screen comes up then goes off. The battery is fully charged.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 22, 2010
My kodak easy share cd14 is showing "lens problem
This problem happens because oflong time no using/ Dust or Lens guide pin damaged. If the lens guide pindamage then there is no chance for repairing . Only solution is replacing thelens. For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if thecamera does not start working then you need to visit service center forreplacing the Lens or Repairing. But before repairing ask service center theapprox cost. if they told you to replacing the lens then do not do that.Because a new lens & service charge cost you near about a new camera price.So best is buy a new camera. If you have any more questions ask me I fell happyto answer your question. Thank you.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html - - - Doit your self lens fix
Oct 26, 2011 | Kodak EasyShare CD14 Digital Camera
Z740 easy share will not power up,tried new batteries ,nothing at
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format.
Jun 08, 2010 | Kodak EasyShare Z740 Digital Camera
Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak easyshare m340 turn on lens come out then shuts off
Dec 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak easy share digital camera m863
I have a Easy Share M863 and have had it less than a year. It was working great and then last week I tried turning it on and it would not open. I thought it might be the battery needed charging so I did that. It still will not open. I contacted Kodak and they told me they would give me 15% on a new digital camera. That is not what I wanted. My camera is not even a year old. It should have lasted longer I think.
Jun 08, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare One Digital Camera Logo
564 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
