Question about Apple iPhone 3G
My iphone 3GS auto shutdown when using applications. Also shutdown during calls. Sometimes, when idle, when incoming call, the phone may shut down also, which means that the phone will not be turned on until i touch it and realised that its off. I had tried restore+backup. Nothing changed. I tried restore and start from zero .. also same problem with the autoshutdown problem. Pls help me.
  • 77 Answers
You need to contact Apple and have it replaced with another iPhone 3GS. There seems to be a problem with them as many have complained about it.
Posted on Aug 21, 2010
  • HL_Lam Jan 17, 2011
    Same problem @ my iPhone 4 ><
    Probably I will return it and hopefully I will get a new one asap
I forgot my iphone 3gs passcode lock
mmmm write on the youtube that problem
Dec 30, 2012 | Apple iPhone 3GS Black (16 GB)
Tip
How to unrestrict you iPhone 3GS to make Voip calls over the 3g network!!!
First of all, you'll need an iPhone 3GS (of course). This trick works for the version 3.1.2 of Apple's firmware. First, you'll need to jailbreak your iPhone 3GS. For that, you'll need to download the blackra1n.exe application from this website: www.blackra1n.com, then you'll need to run the application (nothing complex, just a one-button-easy-process) and wait for your iPhone to reboot (note that after this you won't be able to shutdown your iPhone again, as this is a tethered jailbreak, if you do, it'll restart in restore mode and you'll need to manually boot it again with the blackra1n program). When the jailbreak is done, you'll see a black-drop-shaped icon in the application list on your iPhone, tap it and install the cydia and Rock applications. When you finish installign those, tap the Rock application and then tap on "manage" at the right bottom of your screen. After that, tap "Manage Sources", then "Edit" (top-right of the screen), then "Add" (Top-left), then type exactly this: "http://sinfuliphonerepo.com" (without the quotes). Now, after confirmation, still in Manage>Sources, scroll down until you see a section called "User entered". Tap the arrow to show a list of applications. The first one should be an application called "3G Unrestrictor", install it. After installed, open the application from your springboard and select these application if you have them: Skype, Nibuzz, App Store (Choosing it also unlocks iTunes Store) and any other application that doesn't allow a certain type of connection over the 3G network system. And as a bonus, you might grab some other free applications for your iPhone, such as old game consoles emulators, file managers (iFile Cracked) and more!
on Feb 06, 2010 | Cell Phones
My iphone 3gs automatically shuts down when making a call,sending message or using the camera! drains so much battery
i think its beacause of battery, buy a new one then charge it 8hrs. do not use your phone, charging while your phone is switch off is good for the battery.
Apr 10, 2011 | Apple iPhone 3GS Black (16 GB)
Unlock iphone 3gs 4.1 want to change server
I am enable to get incoming calls in my Iphone 3gs, IOS 4.1
Nov 14, 2010 | Apple iPhone Smartphone
Quick discharging of the Iphone 3gs battery
perfectly normal. as the iphone is a super-powerful smartphone. also it depends on wich application you are using. 3d games, 3g wireless internet and the PUSH notifications, generally contribute to drain the battery's life. to enlarge you battery's duration i would recommend to disable the push notifications, or at least give them a longer refresh delay. also, it would help if you install a battery monitiring application and lock the phone immediatly after use. the drawback is that you wil hae to manually check you e-mails and other things that depends on the push notifications.
Feb 04, 2010 | Apple iPhone (16 GB) Smartphone
Just purchased a new 3GS iphone and it only vibrates with incomin
did you check the little button thingy on the left top part of the phone? i discovered that thing, and i was like, "Whoa!"
Jan 04, 2010 | Apple iPhone Smartphone
Iphone shuts off by itself
It is the phone power saving mode. You should set it to maximum time if you don't want your phone to shutdown rigthway when idle. Go to phone settings do it.
Nov 03, 2009 | Apple iPhone 3G
Iphone hangs during standby mode.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Sep 26, 2009 | Apple iPhone Smartphone
Apple iPhone 3G Logo
1,194 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
